I trying to install xpl-perl the debian repos of binkey.
by running manually xpl-rrd, I get this error
Undefined subroutine &main::HELP_MESSAGE called at /usr/bin/xpl-rrd line 66.
When I look on my old machine to the binary from 0.06, there are different perl modules to use. getopt::Std, nog getop::Long
Do I need a specific package of perl??
xpl-rrd troubles in xpl-perl
- Snelvuur
You should take the latest one from xpl-perl, use the wiki to create your own .deb package, then it will also show which packages you need. He did change the getopt schema's so that is true, this will allow more/better commandline handling.
Well, dd it compile from sources, same error.
Compile and Make test etc works well.
- Snelvuur
Hmm i see, i have the same error. I'll see if beanz is online, if not i'll create a ticket for him.
- Snelvuur
If you know the correct syntax for the xpl-rrd it wont show the HELP message, so i think it should still work then
