Opentherm Monitor - Custom web pages
DieterKoblenz
Post by DieterKoblenz »
Hi there,
Has anyone here made some custom pages for the opentherm monitor system? When I make a new html page in the html subdir, it will only display the text. Is there someone who could help me design or change the "iphone" webpage to support cancelling temperature override and enable/disable hot water function when I am not at home?
DieterKoblenz
Re: Opentherm Monitor - Custom web pages
And I have another question, I am running the monitor now on a Raspberry Pi. I can not start in gui mode, is it possible to make a config file and use that to run the daemon? I need at least a way to configure passworded access so that I can forward the port from my router.
In daemon mode, OTmonitor will use the config file that was created in GUI mode. However, that's not where user names and passwords for web access are stored. Those are in a sqlite3 database called auth/auth.db. You can create it with otmonitor running on another computer and copy it to the Raspberry Pi.
It's also possible to add user accounts via dbus:
dbus-send --print-reply --dest=com.tclcode.otmonitor /Security com.tclcode.otmonitor.AddUser :user :password
Dynamic web pages must have a .tmpl extension in addition to the normal extension that indicates the content type. So, for a dynamic html page you would create a file called something like html/page.html.tmpl
Any lines in the file prefixed with % are executed as Tcl code. Other lines are sent to the browser after substituting Tcl variables and commands. The most interesting values are all stored in the global gui array. So the following code in a file called html/dump.html.tmpl would show all of those values when you access http://*.*.*.*:*/dump.html:
% global gui
<table>
% foreach n [lsort -dictionary [array names gui]] {
<tr><td>$n</td><td>$gui($n)</td></tr>
</table>
Via the websocket (defined in iphone.js) you can send the commands 'Up', 'Down', and 'Prog'. The red arrow currently sends 'Up', the blue arrow sends 'Down', and 'Prog' would need to be sent by whatever button you are going to add to your copy of the iphone.html.tmpl file to cancel the temperature override. You will have to name the file differently because built-in pages take precedence over pages with the same name in the html directory.
To enable/disable hot water function you would need to submit the appropriate serial command via a POST action. See print.html.tmpl for an example of how to do that.
DieterKoblenz
Thank you very much for your help!
Where is the config file from the gui located? So if I copy that config file and the auth database to the raspberry I can set it up on my windows machine and start it in daemon mode on my Pi?
On a Raspberry Pi the default config file is ~/.otmonitorrc. On windows the settings are normally stored in the registry, but you can use a config file by specifying it with the -f option. In theory that should work, although I have never actually tried it.
DieterKoblenz
Currently I am running it like this: ./otmonitor-ahf --webserver=7000 --daemon 192.168.178.20:101
However it doesn't seem to generate any config file, also not when I try to close it.
yjb
Post by yjb »
And one is not even bound to the standard naming and location (~/.otmonitorrc) I'm using:
/opt/opentherm//otmonitor --daemon -f /opt/opentherm/otmonitor.conf
I'm not using all the entries in the config file; this is my config file (to get you going):
cat /opt/opentherm/otmonitor.conf
datalog {
  append true
  file /tmp/otmonitor-data.txt
  enable true
  interval 30000
  itemlist {
    flame
    dhwmode
    chmode
    dhwenable
    diag
    fault
    outside
    temperature
    setpoint
    modulation
    boilertemp
    returntemp
    controlsp
    dhwsetpoint
    chwsetpoint
    timestamp
clock {
  year false
  date false
  auto false
sms {
  enable false
  ventilationfault false
  phonenumber {}
  route {}
  sender {}
  provider VoipPlanet
  password c2VjcmV0
  account {}
  solarfault false
  roomcold true
  watchdogtimer false
  boilerfault true
  commproblem false
email {
  password c2VjcmV0
  server {}
  roomcold true
  boilerfault true
  watchdogtimer true
  solarfault true
  commproblem true
  port 25
  enable false
  secure TLS
  recipient {}
  user {}
  sender {}
  ventilationfault true
logfile {
  pattern otlog-%Y%m%d.txt
  directory /tmp/
  enable true
web {
  theme purple
  enable true
  port 8089
  sslport 8090
  nopass false
  certonly false
connection {
  device {}
  type tcp
  port 1001
  host 192.168.0.62
  enable true
server {
  enable true
  port 7686
  relay true
view {
  tab graph
  order increasing
  sort name
  bitflags false
mqtt {
  devicetype central_heating
  deviceid otmonitor
  retransmit 10
  format json2
  port 1883
  qos 1
  keepalive 120
  username {}
  password {}
  enable false
  messages false
  client sandbox-otmon
  broker localhost
Ghostbird
Post by Ghostbird »
I'm running the otmonitor as a daemon on a raspberry pi (ARMHF), but for some reason it does not seem to use the auth db.
I've pointed it to the correct config file.
However whenever I try to login to the web interface the username and password are rejected.
I even read the password hash from the auth.db file, and compared it to a manual hash of the password, which matched.
Any idea what may be wrong?
The otmonitor is started from rc.local with the line:
otmonitor --daemon --system -f /opt/otmonitor/otmonitor.conf /dev/ttyAMA0 &
The authentication information is in /opt/otmonitor/auth
When I try to connect trough HTTPS I cannot connect and my SSH session displays:
channel 7: open failed: connect failed: Connection refused
Note: For security both HTTP and HTTPS are local connections forwarded trough SSH
Ports used are 80 and 443 (standard HTTP and HTTPS ports) this is of course possible because the otmonitor is started by the system (which has access to port numbers below 1024)
Ghostbird
Post by Ghostbird »
EDIT: Sorry for the double post, but I had a new account, and the previous post had not been approved yet. Then I reread this thread and forgot that I had already posted and said this:
I had the same issue, I solved it by installing and running xorg server on the pi, then using X11 forwarding in the SSH session. Though I don't know how that will work if you're using Windows to connect. I run Debian on my local machine. Then you can just start the otmonitor program with GUI and the GUI will open on your local display as if it were running on your machine instead of the raspberry pi. Though it will probably be very slow if you're not on a LAN connection (I had a rather unstable connection and it was ridiculously slow).
It is a shame the web interface doesn't offer all the GUI options.
Ghostbird wrote:It is a shame the web interface doesn't offer all the GUI options.
I'd be happy to include any code you contribute to fill the gaps.
Ghostbird wrote:I'm running the otmonitor as a daemon on a raspberry pi (ARMHF), but for some reason it does not seem to use the auth db.
Where is the otmonitor binary located? The program looks for the auth db relative to its own location, not relative to the configuration file.
The HTTPS connection problem may be the same discussed in another topic.
Ghostbird
Post by Ghostbird »
Ah, that's unfortunate. I'll have to install the otmonitor in /opt then. I hadn't given much thought to it and installed it in /usr/bin as a normal *nix application, but I should've known that it was slightly different because it was designed multi-platform.
Thanks for the answer I think I'll be able to solve my issues with this.
The reason it works this way is not because the application was designed multi-platform, it's just a choice I made. Under normal conditions the configuration file is ~/.otmonitorrc. Storing data relative to that would put it in the home directory, which I think is undesirable.
However, you can make a symbolic link from /usr/bin to the binary under /opt and things should still work. The program is found via your normal PATH, but the data is located under /opt.
Ghostbird
Post by Ghostbird »
I understand, and I would have made the symbolic link if this was an application that I called from multiple locations. At the moment I'm trying to get it properly configured and secure, which is proving to be elusive, but I will get there. So far I have it either secure, but not connected to the Gateway or connected to the gateway but not sufficiently secure.
