how to change duewi configuration via HSPro2.5.0.55
Posted: Sun Dec 21, 2014 2:46 pm
is it possible to change the duwi dimmer configuration via homeseer?
I would like to try the double click feature and it seems you have to set via 'Add Configuration Settings', enter variable '14' data size '1 byte dec' and assign a desired value of '1'
If it is not possible via HS what would be the alternative? Can it be done by pushing the dimmer rocker?
Already searched for a long time on the internet, but not really found anything that i could use.
