which wall transmitter for HS3
Posted: Wed Mar 11, 2015 4:50 pm
I'm trying to control a Fibaro FGD-211 dimmer with a ZME_WCD1 wall transmitter, this worked with HS2 and Fibaro HC2. I cannot add the WCD1 to the HS3 network, not with the standard Z-wave plugin or with the latest beta. I also tried a ZME_WallC-S, I'm able to join this to the HS3 z-wave network, it even shows it's associated with the dimmer module (after pushing some buttons) for group 1 and 2, but I cannot control the dimmer.
Is there anyone with the same setup? Or should I buy a different wall transmitter?
