Homebuilt OTGW cannot communicate with Honeywell Round
Posted: Thu Sep 17, 2015 4:08 pm
Ordered a kit this week at Kiwi-electronics and soldered it myself (not to experienced so that might be one of the causes
) and it's now only partially working.
What is working is the communication with my Daalderop boiler
What is not working is the communication with my Honeywell Round modulation (also tried the wireless opentherm relay BDR88 but that only has leds so not very helpfull for diagnosing)
The Round modulation is booting up but then after +/- 10 second it's flashing to indicate no Ot communication and I also do not see any status change on the OTmonitor nor commands (also not in diagnose mode)
What I've tried so far with the steps from the troubleshooting page:
No IC1, no OK1
powersupply Resistance between X3 terminals: 3.03K
voltage P5 <-> P14 IC1: 4.99V (polarity ok)
Voltage X1: 24.5V
Current X1: 6.41mA
Connect IC1 P3<-->P5 Current X1: 20.8 mA
Plugin OK1 connect X1 to X2
Voltage X2: 16.30V
Connect IC1 socket P2 <-> P14
Voltage X2: 5.10V
IC1 P3 open Voltage IC1 P18 <--> P5: 0.00V
IC1 P3 <-> P5 Voltage IC1 P18 <--> P5: 2.35V
Pull OK1 X1 & X2 still connected
IC1 P18 <-> P5: 0V
OK1 P3 <-> P4: 0.392V
Remove power
OK1 P3 <-> P4: 98.4Ohm
OK1 back in Poweron
R1: 0.67V
R2: 0.39V
R3: 0.86V
D9: 1.25V
D10: 14.23V
OpenthermMonitor displays following lines
R80000100 Read-Data Status:00000001 00000000
Could you please advise what to check next?
No IC1, no OK1
Voltage X1: 24.5V
Current X1: 6.41mA
Voltage X2: 16.30V
Voltage X2: 5.10V
IC1 P18 <-> P5: 0V
Remove power
OK1 back in Poweron
R1: 0.67V
R2: 0.39V
R3: 0.86V
D9: 1.25V
D10: 14.23V
