What I want to achieve is to be able to turn on and off a light using the * button on a keyfob.
I have a PM30 with the accessory card fitted, so I can configure the keyfob to the PGM output.
The light will be switched from an MQTT topic.
What I am looking for help with is the hardware connection between the PGM output and an arduino which will generate the MQTT messages.
Searching around seem to suggest a voltage divider to step down the voltage.
Has anyone tried this or any other successful approach?
TIA
PGM hardware setup
Moderators: Rene, Willem4ever
Re: PGM hardware setup
I use the * button on the keyfob to lock/unlock my garage door. But I use a software only solution. My software is monitoring the Powerlink port.
Hi Rene,
That sounds interesting - what does your code look out for?
Dad
Dad
