Thin wallswitch
Moderator: Mversluis
DJF3
Thin wallswitch
Post by DJF3 »
Because of cabling and a fibaro module there's not enough space for a normal wall switch..
Do you know if there are thin (ondiepe) wall switches?
DJ
Re: Thin wallswitch
KaKu switches can be flat on the wall. But you probaly don't want to use KaKu so don't . Get everything out of the KaKu switch except the switches. Just wire the fibaro switch to the internal switches in the KaKu
raymonvdm
Re: Thin wallswitch
Post by raymonvdm »
Or place the fibaro module inside the lamp or pattress box in the ceiling
DJF3
Re: Thin wallswitch
Post by DJF3 »
raymonvdm wrote:Or place the fibaro module inside the lamp or pattress box in the ceiling
There's no space either :)
So here's what I have, and (marked in green) what I would love to have..
wall switch
wall switch
raymonvdm
Re: Thin wallswitch
Post by raymonvdm »
There are two types of patress boxes (55mm and 40mm) i think you have the 40mm
One solution is to use a duwi lookalike switch or use some sort of filler to create the needed space
Akatar
Re: Thin wallswitch
Post by Akatar »
zelf zou ik dan voor een pulsschakelaar gaan omdat er een fibaro achterzit
misschien zijn deze ook wat ondieper?
http://www.elektrooke.nl/peha-pulsschak ... GwodPaIOyw
of een duwi wandzender, die kunnen plat op de muur
