Solidstate switch
Posted: Sat Nov 21, 2015 1:12 pm
by Bastiaan
Does anybody knows a Zwave solid state switch ?
Most Fibaro and Qubino work with relais and don't work well when switching (LED) powersupplies that have a high start peak.
Re: Solidstate switch
Posted: Tue Nov 24, 2015 10:36 am
by raymonvdm
I have no issues with relais switches and led drivers. But if you want to use solid state i think you need to use both. Fibaro for switching the solid state relais and the solid state relais for switching the actual load
https://www.vekto.nl/solid-state-relais ... -40A/51598
Posted: Tue Nov 24, 2015 6:57 pm
by Bastiaan
Thanks Good tip. Affordable too.
I got some high Density LED strips with 600 per meter. Double length. The power per strip is too much for an RGbW Fibaro unit unless I split them up. But then the main power will always be on and although it is a switched power it still draws some power. Might need to check with another less powerful power adapter.
Posted: Tue Nov 24, 2015 7:23 pm
by raymonvdm
There are special RGB power units which follow the input of an RGB strip to control levels but use an external powersupply for the power.
I think this is a better solution then using a solid state relais
