CCTV ONVIF DVR to web page.
Posted: Mon Dec 28, 2015 6:52 pm
by paulb
Hi i have a 16 channel ONVIF chinese dvr, i can view it online with xmeye but i wanted to put the streams on a website, main reason for this is the built in webserver only streams one channel at a time and is a bit flimsy. it says on the from H.264 and the version is
Video In: 16
Alarm In: 8
Alarm Output: 1
Audio In: 8
Build Date:2014/2/18 14:17:13
System: V4.02.R11.31152053.10001
Serial ID: 0012123397c3
Any help gratefully received.
Paul
Re: CCTV ONVIF DVR to web page.
Posted: Mon Dec 28, 2015 8:52 pm
by vincenttor
Maybe its better to search for the stream or snapshot links from the connected camera's.
Sometimes when you have a NVR with for example a POE outputs they have a router function ,then you can only connect to the recorder and not by your lan connection on the cams separate.
They have usually another ip range internally.
But when the cams are also viewable by your lan you can try to find the links if they are there and place them on a html/php or whatever page you want to make.
If this does not help, you can maybe use Blueiris.
This does use bandwith, the more megapixels and Fps you use the more cpu it asks.
or Ispyconnect, that software uses less cpu but the viewing goes trough a sort of cloud system.
This can be done different but you'd have to buy the software.
What brand camera's are you using ?
Posted: Sat Feb 06, 2016 10:36 am
by itaishi
Hallo Paul,
i know it is an old thread,
but i need your help.
do you still have this DVR?
did you successed with your problem ?
i can't send emails from the DVR,
this is very annoying,
my DVR (16 Channels) system is V4.02.R11.31152053.10001 (i guess its chineis , non brand one).
Build Date 2013-09-14 14:31:26
NatStatus DisEnable (what id that suppose to mean ????)
i can connect to the DVR with my mobile online.
i could connect in the past from my PC Online.
but i never could email Alert or even TEST.
i use Google Email
already use :
port 25 , to aspmx.l.google.com SMTP SERVER
port 465 , with SSL checked, to smtp.gmail.com.
(this is google instruction: https://support.google.com/a/answer/176600?hl=en)
(used less secure password: https://support.google.com/accounts/answer/6010255)
no success at all with sending emails #-o
i guess it something with the DVR no properly configured with network.
The DVR IP is local and Static, with 8.8.8.8 as the primary DNS Server.
i can view the cams in another PC in the LAN .
any way to check it?
do any of the other "NETSERVICES" must be configured?
RTSP? ARSP ? DDNS? PPPOE? FTP? UPNP? NTP? DHCP?
maybe must do a firmware update (its very risky an there is no brand behind it).
any help would be pleased.
