Timeout PIR NEXT+ MCW
Posted: Sat Jan 16, 2016 12:00 pm
I have connected my Powermax+ via its X10 output to my home automation system (Homegenie). This way I can use alarm on/off and sensor on/off signals in my home automation. My ideas was to use the MCW NEXT+ PIRs as motion sensors but after a few weeks of testing have to conclude that this is not really possible as the PIRs do not continuously send motion signals.
The behavior I noticed and also read in the web is that these sensor have a timeout of about 2 mins after detecting motion. When they come back on and there is motion, they do not send a signal but go back to sleep again for the next 2 mins. If there is no motion they will detect the next motion when that happens and send a signal. This work fine for motion detection in an alarm system and to switch on a light but does not allow me to keep a light on as long as someone is in the room.
Can someone confirm this behavior and let me know whether this is because of the sensors, the Powemax+ module or the X10 signalling? Also, would like to know if this behavior is not there when using the RS232 output as I still have a module lying around to use that output.
Thanks
Pim
Thanks
Pim
