Control setpoint change after OTG reset ???
Posted: Sat Jan 30, 2016 8:31 pm
I saw strange behaviour, that I can't explain. Can anybody help me?
Room setpoint was set to 22.0 C.
Control setpoint (calculated by QAA73) was 41.92 C.
After OTG reset and without any other modification, the control setpoint was 46.30 C
Here is the log:
Thank you for any suggestion....
roman
Here is the log:
17:49:13.610686 T80001300 Read-Data Status: 00010011 00000000
17:49:13.879016 BC000132A Read-Ack Status: 00010011 00101010
17:49:14.650487 T90101600 Write-Data Room setpoint: 22.00
17:49:14.932857 B50101600 Write-Ack Room setpoint: 22.00
17:49:15.601870 T10171600 Write-Data Room Setpoint CH2: 22.00
17:49:15.921637 BD0171600 Write-Ack Room Setpoint CH2: 22.00
17:49:16.641923 T101814A4 Write-Data Room temperature: 20.64
17:49:16.909458 BD01814A4 Write-Ack Room temperature: 20.64
17:49:17.628326 T80800000 Read-Data Message ID 128: 0
17:49:17.898363 BE0800000 Data-Inv Message ID 128: 0
17:49:18.617321 T10821953 Write-Data Message ID 130: 6483
17:49:18.885905 BD0821953 Write-Ack Message ID 130: 6483
17:49:19.605968 T807F0000 Read-Data Slave product version: 0 0
17:49:19.875735 B407F6401 Read-Ack Slave product version: 100 1
17:49:20.595818 T80001300 Read-Data Status: 00010011 00000000
17:49:20.864489 BC000132A Read-Ack Status: 00010011 00101010
17:49:21.584270 T100129EC Write-Data Control setpoint: 41.92
17:49:21.852986 BD00129EC Write-Ack Control setpoint: 41.92
17:49:22.573047 T10081FF8 Write-Data Control setpoint 2: 31.97
17:49:22.840622 BD0081FF8 Write-Ack Control setpoint 2: 31.97
17:49:23.610986 T90383700 Write-Data DHW setpoint: 55.00
17:49:23.963271 B50383700 Write-Ack DHW setpoint: 55.00
17:49:24.582425 T80200000 Read-Data DHW2 temperature: 0.00
17:49:24.951301 BE0200000 Data-Inv DHW2 temperature: 0.00
17:49:25.570940 T801A0000 Read-Data DHW temperature: 0.00
17:49:25.939808 B401A3154 Read-Ack DHW temperature: 49.33
17:49:26.558570 T80001300 Read-Data Status: 00010011 00000000
17:49:26.928359 BC000132A Read-Ack Status: 00010011 00101010
17:49:27.547228 T001B0000 Read-Data Outside temperature: 0.00
17:49:27.915819 B401B03F4 Read-Ack Outside temperature: 3.95
17:49:28.586815 T80190000 Read-Data Boiler water temperature: 0.00
17:49:28.905586 BC0192CAC Read-Ack Boiler water temperature: 44.67
17:49:29.575537 T801C0000 Read-Data Return water temperature: 0.00
17:49:29.894035 B401C2068 Read-Ack Return water temperature: 32.41
17:49:30.564010 T801F0000 Read-Data Flow temperature CH2: 0.00
17:49:30.882876 B401F1ED8 Read-Ack Flow temperature CH2: 30.84
17:49:31.552979 T00110000 Read-Data Relative modulation level: 0.00
17:49:31.870921 BC0110000 Read-Ack Relative modulation level: 0.00
17:49:32.540942 T80001300 Read-Data Status: 00010011 00000000
17:49:32.859272 BC000132A Read-Ack Status: 00010011 00101010
17:49:33.533721 T80130000 Read-Data DHW flow rate: 0.00
17:49:33.846949 B70130000 Unk-DataId DHW flow rate: 0.00
17:49:34.519199 T001D0000 Read-Data Solar storage temperature: 0.00
17:49:34.835934 BF01D0000 Unk-DataId Solar storage temperature: 0.00
17:49:35.558502 T001E0000 Read-Data Solar collector temperature: 0.00
17:49:35.824829 B601E0000 Data-Inv Solar collector temperature: 0.00
17:49:36.545990 T00210000 Read-Data Exhaust temperature: 0.00
17:49:36.814720 B40210025 Read-Ack Exhaust temperature: 0.14
17:49:37.534814 T9081020E Write-Data Message ID 129: 526
17:49:37.801285 B5081020E Write-Ack Message ID 129: 526
17:49:38.522199 T80001300 Read-Data Status: 00010011 00000000
17:49:38.790785 BC000132A Read-Ack Status: 00010011 00101010
17:49:39.510834 T90101600 Write-Data Room setpoint: 22.00
17:49:39.779162 B50101600 Write-Ack Room setpoint: 22.00
17:49:40.499792 T10171600 Write-Data Room Setpoint CH2: 22.00
17:49:40.883691 BD0171600 Write-Ack Room Setpoint CH2: 22.00
17:49:41.488548 T101814A4 Write-Data Room temperature: 20.64
17:49:41.756154 BD01814A4 Write-Ack Room temperature: 20.64
17:49:42.527375 T80800000 Read-Data Message ID 128: 0
17:49:42.808548 BE0800000 Data-Inv Message ID 128: 0
17:49:43.479269 T10821953 Write-Data Message ID 130: 6483
17:49:43.797062 BD0821953 Write-Ack Message ID 130: 6483
17:49:44.518439 T80001300 Read-Data Status: 00010011 00000000
17:49:44.786667 BC000132A Read-Ack Status: 00010011 00101010
17:49:45.505763 T100129EC Write-Data Control setpoint: 41.92
17:49:45.775229 BD00129EC Write-Ack Control setpoint: 41.92
17:49:46.495117 T10081FF8 Write-Data Control setpoint 2: 31.97
17:49:46.762895 BD0081FF8 Write-Ack Control setpoint 2: 31.97
17:49:47.483799 T90383700 Write-Data DHW setpoint: 55.00
17:49:47.752366 B50383700 Write-Ack DHW setpoint: 55.00
17:49:48.472057 T80200000 Read-Data DHW2 temperature: 0.00
17:49:48.740679 BE0200000 Data-Inv DHW2 temperature: 0.00
17:49:49.462051 T801A0000 Read-Data DHW temperature: 0.00
17:49:49.729507 B401A3154 Read-Ack DHW temperature: 49.33
17:49:50.449232 T80001300 Read-Data Status: 00010011 00000000
17:49:50.716835 BC000132A Read-Ack Status: 00010011 00101010
<---reset--->
17:49:57.802246 ΓΌ^DOpenTherm Gateway 4.2.5
17:49:58.048873 T00000000 Read-Data Status: 00000000 00000000
17:49:58.363788 B4000002A Read-Ack Status: 00000000 00101010
17:49:58.983706 T00000000 Read-Data Status: 00000000 00000000
17:49:59.352108 B40000008 Read-Ack Status: 00000000 00001000
17:50:00.023435 T90020004 Write-Data Master configuration: 00000000 4
17:50:00.341931 B50020004 Write-Ack Master configuration: 00000000 4
17:50:01.010902 T00030000 Read-Data Slave configuration: 00000000 0
17:50:01.328514 BC0032904 Read-Ack Slave configuration: 00101001 4
17:50:02.002384 T907E0101 Write-Data Master product version: 1 1
17:50:02.515160 B507E0101 Write-Ack Master product version: 1 1
17:50:02.996106 T807F0000 Read-Data Slave product version: 0 0
17:50:03.307315 B407F6401 Read-Ack Slave product version: 100 1
17:50:03.983881 T90012E4C Write-Data Control setpoint: 46.30
17:50:04.304888 B50012E4C Write-Ack Control setpoint: 46.30
17:50:04.975910 T00001100 Read-Data Status: 00010001 00000000
17:50:05.294914 BC0001100 Read-Ack Status: 00010001 00000000
17:50:05.964669 T00060000 Read-Data Remote parameter flags: 00000000 00000000
17:50:06.275973 BC0060707 Read-Ack Remote parameter flags: 00000111 00000111
17:50:06.993686 T90082088 Write-Data Control setpoint 2: 32.53
17:50:07.265160 B50082088 Write-Ack Control setpoint 2: 32.53
17:50:07.984658 T900E6400 Write-Data Maximum relative modulation level: 100.00
17:50:08.249322 B500E6400 Write-Ack Maximum relative modulation level: 100.00
roman
