hello I am a layman in the field of domotica but I have a challenge and I hope anyone can help me with this . I will try to explain it as well as possible because my english is not my mother language.
I have a connection with 1 fibaro dimmer 2 and a double pushbutton on a serial switch. Is it possible to operate 2 separate lights with 1 fibaro dimmer 2? The right button for one light and one with the left button.
I hope anyone can help me out because it begins to me to be a bit frustrating.
Thx in advance!
Fibaro dimmer 2 with double pushbutton
Re: Fibaro dimmer 2 with double pushbutton
There is only 1 output on the dimmer 2 so you can only directly control 1 light. You can connect a second switch to the dimmer though which you can use to control other z-wave devices using an association.
