CM15pro Windows 10 64 bit
I want to upgrade my 32 bit windows 10 to 64-bit. Under 32 bit the CM15pro works fine. Before I start with the upgrade I have a question: will it also work with 64 bit Windows 10?
Re: CM15pro Windows 10 64 bit
I use CM15 on Windows 10 64 bit.
I have problems but I think it's the Homeseer plugin. And the problem is too much traffic. Hence no problem getting traffic.
Regards
Morten
Regards
Morten
Thank you for your quick response. I am using X10 commander from Melloware to "manually" control the lights in my house. The CM15 is programmed with ActiveHomePro. Do you think this keeps working with 64 bit? The reason I have to upgrade is that I am going to use software from my work at home that only works with 64 bit. About 80% of my lights are controlled by the CM15 so upgrading is a bit tricky (if something works don't mess with it
regards
Jedd
regards
Jedd
I have an old ActiveHomePro on the PC. So I know it can run. But I never used it for anything other than a driver.
I think it will work fine.
Regards
Morten
Regards
Morten
** solved **
Upgraded my PC to windows 10 64 bit. The version of Active Home on the DVD that came with the CM15Pro (>5 years ago) wouldn't install after. There was an error message about the operating system, in 32 bit there were no issues with the installation.
After downloading a newer version of Active Home the program installed and works as before! Also the Melloware X10 commander software works with no problem. So now I am the proud owner of a X10 64 bit system
Thank you for your advice.
Regards
Jedd
Regards
Jedd
I am suprised that Jedd has CM 15 pro software that runs on Windows 10.
Since I upgrade from Windows 7 to Windows 10 my CM15 software from Active Home doesn't work anymore
Could any one tell me where I can download the CM15 version for Windows 10?
kind regards Henk.
kind regards Henk.
