Downloads
Forum about Toon related manuals and tutorials. Read-only for most members.
Locked
Downloads
This thread mostly consists of attachments, available for download. To keep things tidy, it will be read-only. When you have stuff you deem interesting for this thread, PM me and I'll see to it.
added 2018-02-13: busybox-1.27.2-r4: Busybox with sha512 password hashing, and the combined features of 1.18.3-r42.1 and 1.27.2-r1, as published by Quby.
(be sure to install all three packages):
http://files.domoticaforum.eu/uploads/T ... r4_qb2.ipk
added 2017-05-29: wget with ssl support, and cron (for running cron jobs ;-) )
replaced 2017-05-04: Toon-buienradar, version 7.3
added 2017-03-01: x11vnc-bitbake-recipe.zip, x11vnc bitbake recipe, for those of you who want to roll their own.
replaced 2017-02-16: Buienradar, by Toonz, updated to v7.
added 2017-02-15: uboot-and-openocd-cfg-for-rooting-toon.zip. This archive contains a boot loader image for toon and a configuration file for OpenOCD software, to be used in combination with a JTAG interface adapter. See manuals/tutorials Rooting toon for an explanation on how to actually use it.
added 2017-02-03: Boiler status app, first release. This app will work in toons with 3.0.29 <= FW version <= 3.5.4. Later versions have http output of happ_thermstat, on which this app relies, screwed up. Installation instructions are included in the .zip file.
2016-09-28: To extract the x11vnc package, on linux machines (and possibly Macs), you may need to concatenate the two files before you can extract the .ipk package. Some older versions of unzip do not support multi-file archives.
Like this:
cat x11vnc.z01.zip x11vnc.zip > x11vnc_complete.zip
and then:
unzip x11vnc_complete.zip
Thanks RomMon, for noticing.
added 2016-08-11: sftp-server. tested on fw 3.4.4, with dropbear_2015.71. Unzip, upload the .ipk to toon and install. I got bored with downloading files through scp, so added this server.
replaced 2016-07-02: dropbear (the previous one was the original version from the oe-tree)
added 2016-06-01: dropbear, xvnc for toon.
cron_3.0pl1-r8_qb2.ipk.zip
cron for toon
(20.9 KiB) Downloaded 1278 times
wget_1.12-r8.2_qb2.ipk.zip
wget for toon, with ssl support
(143.45 KiB) Downloaded 1100 times
ToonBuienradar_V7.3.zip
(65.08 KiB) Downloaded 1088 times
(1.97 KiB) Downloaded 1005 times
(84.32 KiB) Downloaded 2024 times
boilerstatus-0.1.zip
(20.31 KiB) Downloaded 1103 times
openssh-sftp-server_7.3p1-r10.0_qb2.zip
sftp-server for toon
(44.92 KiB) Downloaded 2784 times
dropbear_2015.71-r0_qb2.ipk.zip
dropbear for toon, updated
(122.8 KiB) Downloaded 3707 times
x11vnc.z01.zip
xvnc for toon, part 2 of 2
(256 KiB) Downloaded 1442 times
x11vnc.zip
xvnc for toon, part 1 of 2
(185.19 KiB) Downloaded 1460 times
Last bumped by marcelr on Thu Aug 11, 2016 5:03 pm.
Locked
Return to “Manuals/tutorials”
