However now the switches has associated itself with another device which is more disturbing
How can i prevent this from happening? I have already tried the following:
UZB Firmware upgraded from 5.0.1 to 5.0.6 (http://domoticaforum.eu/viewtopic.php?f ... 266#p80061)
Z-Wave plugin upgraded from 3.0.1.25 to 3.0.1.83
Note: It is possible that Junior is causing this issue because he likes to click on the buttons a lot as we are still in the process of learning him not to push on every freaking button he finds in the house!! However if i look into the manual i don`t see and options to perform associations on the local device?
However is see a child lock function:
Child Protection
The device can be turn into a child protection mode. In this mode all local operation is disabled.
The child protection mode MUST be turned on wirelessly. However in protected by sequence mode it is possible to unlock the device for local operation with a triple click. The unlock state will last for 5 seconds.
But the manual does not tell me how to set this option
