Toon firmware: issues (and solutions)
maomanna
Re: Toon firmware: issues (and solutions)
Post by maomanna »
is there a way to fix the vpn directory, problem is posted in viewtopic.php?f=87&t=11449&hilit=vpn&start=270#p85759
I get this error:
You are currently running version 3.7.9
Which version do you want to upgrade to? You can look at the list of currently k                                          nown Toon versions at https://notepad.pw/raw/6fmm2o8ev
4.9
Please enter a valid version!
4.9.11
4.10.6
Alright, I will try to upgrade to 4.10.6
Waiting for tunnel to be alive and configured...
Could not enable VPN in a normal reasonable time.. exiting!
DEBUG information:
192.168.88.0/24 dev wlan0  src 192.168.88.19
default via 192.168.88.1 dev wlan0
# <persistent /etc/hosts content can be added to /etc/hosts.template file>
127.0.0.1               localhost.localdomain           localhost               eneco-001-282734
172.26.96.1             feed.hae.int            feed
END DEBUG information
killall: openvpn: no process killed
Post by TheHogNL »
maomanna wrote:I'd like to update my toon from 3.7.9. to 4.x.x but it seems my VPN connection isnt working.
/etc/openvpn/vpn.conf exists and points to /etc/openvpn/vpn where my .cert & .key etc should be, but the directory vpn is missing.
How can i fix this problem?
is there a eneco-something.tar.gz file in the /etc/openvpn directory? If yes then just extract that. That file contains the keys and crt for each seperate toon.
If not, there is no way to get the vpn working anymore or ask a friend to share his keys. But remember that you can not have two vpn's running with the same key.
maomanna
Post by maomanna »
there is no eneco-....tar.gz in that directory.
I've asked quby to send me those files.
Post by TheHogNL »
maomanna wrote: I've asked quby to send me those files.
Let us know if that works.
Fietspomp
Post by Fietspomp »
I have few questions. On one of my Toons the time was completely wrong (Jan 2011).
Tried to figure out if Chrony was working, so I installed xinetd on my debian server to make sure I have a proper server to sync with.
210 Number of sources = 1
MS Name/IP address         Stratum Poll Reach LastRx Last sample
^? 192.168.1.3                   2   8     3   114    +37ms[  +37ms] +/-   81ms
eneco-001-237576:~# chronyc tracking
Reference ID    : 127.127.1.1 ()
Stratum         : 10
Ref time (UTC)  : Thu Mar 15 18:05:38 2018
System time     : 0.000000000 seconds fast of NTP time
Last offset     : 0.000000000 seconds
RMS offset      : 0.000000000 seconds
Frequency       : 5.844 ppm fast
Residual freq   : 0.000 ppm
Skew            : 0.000 ppm
Root delay      : 0.000000 seconds
Root dispersion : 0.000001 seconds
Update interval : 0.0 seconds
Leap status     : Not synchronised
Seems to have reached my NAS (192.168.1.3), but still Leap status is not sync'd? Anybody got different results?
Also with the latest firmware the stupid message that Service center can't be reached keeps popping up even tho I modified the correct file.
Post by TheHogNL »
I have
^* ntp4.bit.nl                   1  10   377   126   +708us[ +996us] +/- 3722us
Reference ID    : 213.136.0.252 (ntp4.bit.nl)
Stratum         : 2
Ref time (UTC)  : Thu Mar 15 18:42:38 2018
System time     : 0.000017758 seconds fast of NTP time
Last offset     : 0.000101874 seconds
RMS offset      : 0.000324824 seconds
Frequency       : 9.368 ppm fast
Residual freq   : 0.002 ppm
Skew            : 0.113 ppm
Root delay      : 0.006678 seconds
Root dispersion : 0.001394 seconds
Update interval : 1032.4 seconds
Leap status     : Normal
So it seems that your chrony isn't working; not reaching your nas.
I had to put this into /etc/chrony.conf to get the clock synchronized:
# ntp servers in the Netherlands (main application area of toon)
server 0.nl.pool.ntp.org minpoll 8
server 1.nl.pool.ntp.org minpoll 8
server 2.nl.pool.ntp.org minpoll 8
server 3.nl.pool.ntp.org minpoll 8
# driftfile location
driftfile /var/lib/chrony/chrony.drift
#log tracking measurements statistics
logdir /var/log/chrony
dumponexit
dumpdir /var/lib/chrony
local stratum 10
allow 10/8
allow 192.168/16
# Generate syslog messages if large offsets occur (> x secs)
logchange 10
# Specify that the real time clock keeps UTC not local time
rtconutc
#rtcfile /var/lib/chrony/chrony.rtc
# Step system clock if large correction is needed (> x secs within y clkupdates)
makestep 1000 100
# Trim the system clock on boot-up. (> x secs from host)
initstepslew 30 0.nl.pool.ntp.org
# Stop bad estimates upsetting machine clock
maxupdateskew 100.0
Fietspomp
Post by Fietspomp »
Thanks for the replies guys!
Used Toonz' config and now it works, even tho I though I read in the rooting manual NTP servers didn't work.
Now to search and remove the nagging "no connection to service center" banner.
Strange thing is when I click it it says Im connected to Eneco so the spoof in the InternetSettingsApp.qml works sort of...
Fietspomp wrote:Used Toonz' config and now it works, even tho I though I read in the rooting manual NTP servers didn't work.
I know, that should be updated in the manual.
Post by TheHogNL »
Fietspomp wrote:Thanks for the replies guys!
This is because BXT (boxtalk, the internals of the toon) has the status set that there is no connection to the service center.
The modification in internetsettings is only to fool that app (the screen you see) and to fool the wifi icon.
But the banner itself is being fed from BXT itself. So everytime a connection to the internet is made, but the service center is unavailable this message reappears. This is normally only after a startup. But if your internet is broken, or your wifi disconnects all the time, the message reappears also while the Toon is running.
Haven't found out how to block the message myself. I am only seeing the message after a reboot. My internet is flawless :P But I'll take a look at the message part of the code this weekend to check if there is a way to block it. On the forum there are some people who did block the message bar completly but this is maybe something you don't want because you will miss other messages also.
Fietspomp
Post by Fietspomp »
Makes some sense, I was rebooting Toon all the time, left it on all night and now the message is not returning indeed.
Internet here is also quite stable, as long as Ziggo stays stable :roll:
Fietspomp wrote:Now to search and remove the nagging "no connection to service center" banner.
My approach is to comment (or remove) the line 'notifications.init' in ..\qml\Canvas.qml
Component.onCompleted: {
//		notifications.init();
This will remove the banner completely without impacting other functionality.
Banner is pretty useless anyway if you ask me
Post by TheHogNL »
Alright, I managed to remove the annoying network error notification without disabling the notification completly.
Find the "function show" in /qmf/qml/qb/notifications/NotificationBar.qml and add the line shown below (the line between the two comment lines) as the first line after the opening of the show function:
        function show(expanded) {
//mod to remove network errors in notification bar
                notifications.removeByTypeSubType("error","network");
//end mod
                if (notifications.count === 0 || blockConditions)
This will delete each network error notifcations just before they are shown.
PowerAce
Post by PowerAce »
Hi TheHogNL,
I've tried your mod for the NotificationBar.qml file. Unfortunately for my Toon (FW 4.10.6) this is not working. When i reboot Toon it stops somewhere halfway and ends with a 'white' screen. Luckily i was still able to log in using SSH.
I had the mod inserted around line 27 is that correct? It looks by the way that your file is different anyway, when i look at the very last line of your code just after '#end mod'. Yours says something about blockConditions which i don't see in my NotificationBar.qml
Regards
Fietspomp
Post by Fietspomp »
Nice, I'll try it tonight!
Return to “Toon Firmware”
