i try to sent a switch command to the source webserver.
but i am not sure it's the richt one.
i use the command
http://192.168.0.xxx:8080/cc.html?applid=41&cmd=off
the applid is the id i found in the database en match the device i want to switch off
i get the 404 error response.
how to sent a switch command with html
Re: how to sent a switch command with html
solved
i used the wrong link
this is the one to use
for off
http://192.168.0.xxx:8080/api/actions.h ... hoff&id=33
for on
http://192.168.0.xxx:8080/api/actions.h ... chon&id=33
for the list of device id's u can use this
http://192.168.0.xxx:8080/api/data.xml?type=appliances
for off
for on
Nice , thanks
I can use this too
Super
I can use this too
Super
Using this for voice control of Plugwise, sending commands from Amazon Echo through HAbridge to Source. It's reasonably stable, so I'm happy that I can still use my plugs. They are slowly turning obsolete after all...
