more then 50 modules
Post by Harry »
i like to expan my source network, but is it possible to add more the 50 modules ?
LoveHomey
Re: meer dan 50 modules
Post by LoveHomey »
see the licence page in your source program in program section how much you are licensed to. you can buy more licenses
Akatar
Post by Akatar »
it depends
you can check this in youre source software
check: instellingen -->programma
Post by Harry »
oke i see licence 25 to 250 modules then i would be oke :D
PietjeNL
Re: more then 50 modules
Post by PietjeNL »
Max 64 modules a network, or you need a second network aka stick an +C+ module.
Akatar
Post by Akatar »
in that case you need the "mulitple network" option
Post by Harry »
how can i see if i have the multiple network option ?
i have the licence options
* 25 to 250 modules
* Data export
* web server
and run Source version:
Pro 2.25
Akatar
Post by Akatar »
in my case:
Post by Harry »
now i am stil not sure how much modules can be added to my source software?
do i need more licenceopties.
PietjeNL
Post by PietjeNL »
You can have allot of modules and stick's/networks.
But without the multiple networks you can only use 1 stick/network of 64 modules at the time.
Post by Harry »
someone now what a mulitiple network option cost?
Akatar
Post by Akatar »
i thought there was a hack to do this, it was somewhere on this board
jeroenc
Post by jeroenc »
How did you get "data export"?
Sent from my iPhone using Tapatalk
Akatar
Post by Akatar »
jeroenc wrote:How did you get "data export"?
that was a standard feature.
Post by Harry »
i had to request data export.
in the first versions it was standard, after a upgrade it was suddenly a licencend option.
i got the option for free.
i only need the multi network, i think that is an expencive upgrade.
Return to “Plugwise Forum”
