Visonic GSM Module - Auxiliary Port
Posted: Sat Feb 04, 2017 7:21 pm
by dhani3
Hello!
I'm planning to connect my Visonic PowerMax+ to my Raspberry Pi and found a lot of usefull information in this board.
My problem is, that my RS232 interface of the PowerMax+ is connected to the Visonic GSM Module. I found an Auxiliary Port on the GSM Module.
Is it possible to connect this port to the raspberry pi and receive status updates of the powermax+?
If that is not working - is it possible to split the RS232 cable to be able to connect both, the raspberry pi and the gsm module?
I hope anyone can help me.
Best regards,
Daniel
Re: Visonic GSM Module - Auxiliary Port
Posted: Wed Feb 08, 2017 6:05 pm
by Edwin2008
Perhaps a Rs232 server? There are some models that can connect from more then one computer.
Posted: Thu Feb 09, 2017 11:10 am
by raymonvdm
Posted: Thu Feb 09, 2017 10:25 pm
by johnz
You should be able to use the auxiliary port on the gsm module (if you mean the one at the bottom). That is where I put it and it works with the remote programming software as well as the Powerlink alternatives. Nothing else required.
John
Posted: Wed Feb 15, 2017 9:21 pm
by dhani3
Hi!
Thanks a lot for the replies. They helped a lot.
johnz wrote:You should be able to use the auxiliary port on the gsm module (if you mean the one at the bottom). That is where I put it and it works with the remote programming software as well as the Powerlink alternatives. Nothing else required.
John
That sounds great to me.
Would you be so kind to describe your setup? Have you followed the instructions in
viewtopic.php?f=68&t=6517 ?
How do you connect to the Auxilliary port? Have you built your own cable + connector? Which device do you use to connect the aux port to?
I'm planning to connect my Visonic PowerMax+ either via an ESP8266 as described in
viewtopic.php?f=68&t=11254 or via a Raspberry Pi.
Best regards,
Daniel
Posted: Fri Feb 17, 2017 12:21 am
by johnz
Hi Daniel,
I do not think this will help you much, I have not built my own serial cable, I already had the remote programming software kit with cable and RS232 connector.
I am using the Visonic driver software by Bart Bakels
domoticaforum.eu/viewtopic.php?f=68& ... mp;t=11129, which can communicate with Homeseer, Domoticz etc. through JSON commands.
In my setup I have one RJ45 cable between Powermax and GSM module, and one RJ 45 cable from the bottom of the GSM module into an RJ 45 to RS232 connector adapter (which came with the kit). In my case this cable is connected to a Digi portserver (for which I did build an adapter cable) with which the serial connection is accessible over tcp/ip.
Best regards,
John
Posted: Wed Feb 22, 2017 3:14 pm
by dhani3
Big thanks for your help john.
Trying to build the one on my own.
Best regards,
Daniel
