Cool..... even if it is just a beep.
I'm afraid so, there won't be a lot to choose from.
Just installed a modified kernel and a bunch of modules for the sound subsystem, and ALSA utilities. This is what I get from amixer:
toon:~/kernel_sound# amixer
Simple mixer control 'Mic Bias Voltage',0
Capabilities: enum
Items: 'off' '2V' '2.5V' 'AVDD'
Item0: '2.5V'
Simple mixer control 'Beep Cos(x) LSB',0
Capabilities: volume volume-joined penum
Playback channels: Mono
Capture channels: Mono
Limits: 0 - 255
Mono: 227 [89%]
Simple mixer control 'Beep Cos(x) MSB',0
Limits: 0 - 255
Mono: 126 [49%]
Simple mixer control 'Beep Length LSB',0
Limits: 0 - 255
Mono: 238 [93%]
Simple mixer control 'Beep Length MID',0
Limits: 0 - 255
Mono: 0 [0%]
Simple mixer control 'Beep Length MSB',0
Limits: 0 - 255
Mono: 0 [0%]
Simple mixer control 'Beep Sin(x) LSB',0
Limits: 0 - 255
Mono: 216 [85%]
Simple mixer control 'Beep Sin(x) MSB',0
Limits: 0 - 255
Mono: 16 [6%]
Simple mixer control 'Beep generator Enable/Disable',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Beep generator Volume Control (0=-61dbdB, 6',0
Capabilities: volume penum
Playback channels: Front Left - Front Right
Capture channels: Front Left - Front Right
Limits: 0 - 63
Front Left: 63 [100%]
Front Right: 63 [100%]
Simple mixer control ' MIC1LM CM Setting',0
Capabilities: enum
Items: 'floating' 'connected to CM internally'
Item0: 'floating'
Simple mixer control ' MIC1LP CM Setting',0
Capabilities: enum
Item0: 'floating'
Simple mixer control ' MIC1RP CM Setting',0
Capabilities: enum
Item0: 'floating'
Simple mixer control 'ADC Mute',0
Capabilities: enum
Items: 'Unmute' 'Mute'
Item0: 'Unmute'
Simple mixer control 'ADC Processing Block Selection(0 <-> 25)',0
Limits: 0 - 18
Mono: 5 [28%]
Simple mixer control 'AGC Attack Time control',0
Limits: 0 - 31
Mono: 0 [0%]
Simple mixer control 'AGC Decay Time control',0
Limits: 0 - 31
Mono: 0 [0%]
Simple mixer control 'AGC Maximum PGA Control',0
Limits: 0 - 119
Mono: 127 [107%]
Simple mixer control 'AGC Noice bounce control',0
Limits: 0 - 31
Mono: 0 [0%]
Simple mixer control 'AGC Signal bounce control',0
Limits: 0 - 15
Mono: 0 [0%]
Simple mixer control 'AGC Target Level Control',0
Limits: 0 - 7
Mono: 7 [100%]
Simple mixer control 'Audio Gain Control (AGC)',0
Capabilities: pswitch pswitch-joined penum
Mono: Playback [on]
Simple mixer control 'CM selection for ADC IP M-terminal',0
Capabilities: enum
Items: 'off' '10k' '20k' '40k'
Item0: 'off'
Simple mixer control 'DAC',0
Capabilities: pvolume penum
Limits: Playback 0 - 140
Mono:
Front Left: Playback 127 [91%]
Front Right: Playback 127 [91%]
Simple mixer control 'DAC Processing Block Selection(0 <-> 25)',0
Limits: 0 - 25
Mono: 1 [4%]
Simple mixer control 'DAC Volume soft stepping',0
Capabilities: enum
Items: '1 step/sample' '1 step/2 sample' 'disabled'
Item0: '1 step/sample'
Simple mixer control 'DAC volume Control register/pin',0
Capabilities: enum
Items: 'control register' 'pin'
Item0: 'control register'
Simple mixer control 'DAC volume Extra control',0
Capabilities: enum
Items: 'L&R Ind Vol' 'LVol=RVol' 'RVol=LVol'
Item0: 'L&R Ind Vol'
Simple mixer control 'DRC Enable/Disable',0
Capabilities: enum
Item0: 'Enabled'
Item1: 'Enabled'
Simple mixer control 'DRC Hysteresis value (0=0db, 3=3db)',0
Limits: 0 - 3
Mono: 3 [100%]
Simple mixer control 'DRC Threshold value (0=-3db, 7=-24db)',0
Limits: 0 - 7
Mono: 3 [43%]
Simple mixer control 'DRC attack rate',0
Limits: 0 - 15
Mono: 0 [0%]
Simple mixer control 'DRC decay rate',0
Limits: 0 - 15
Mono: 0 [0%]
Simple mixer control 'DRC hold time',0
Limits: 0 - 15
Mono: 7 [47%]
Simple mixer control 'HP Analog Gain Volume(0=0dB, 127=-78.3dB)',0
Limits: 0 - 127
Front Left: 127 [100%]
Front Right: 127 [100%]
Simple mixer control 'HP Output common-mode voltage control',0
Capabilities: enum
Items: '1.35V' '5V' '1.65V' '1.8V'
Item0: '1.35V'
Simple mixer control 'HP driver Volume(0=0dB, 9=9dB)',0
Limits: 0 - 9
Front Left: 0 [0%]
Front Right: 0 [0%]
Simple mixer control 'HP driver mute',0
Capabilities: pswitch penum
Mono:
Front Left: Playback [on]
Front Right: Playback [on]
Simple mixer control 'Headset detection Enable/Disable',0
Capabilities: enum
Item0: 'Enabled'
Simple mixer control 'Left DAC Mute',0
Capabilities: enum
Item0: 'Unmute'
Simple mixer control 'Left DAC input selection',0
Capabilities: enum
Items: 'off' 'left data' 'right data' '(left + right)/2'
Item0: 'left data'
Simple mixer control 'Left Output Mixer DAC_L To HPL Driver switc',0
Mono: Playback [off]
Simple mixer control 'Left Output Mixer DAC_L To Left Mixer Amp s',0
Mono: Playback [on]
Simple mixer control 'Left Output Mixer MIC1LP To Left Mixer Amp ',0
Simple mixer control 'Left Output Mixer MIC1RP To Left Mixer Amp ',0
Simple mixer control 'MIC PGA Control',0
Limits: 0 - 119
Mono: 0 [0%]
Simple mixer control 'MIC PGA Setting',0
Capabilities: enum
Items: 'Gain controlled by D0-D6' '0db Gain'
Item0: '0db Gain'
Simple mixer control 'MIC1LM selection for ADC I/P M-terminal',0
Capabilities: enum
Item0: 'off'
Simple mixer control 'MIC1LM selection for ADC I/P P-terminal',0
Capabilities: enum
Item0: 'off'
Simple mixer control 'MIC1LP selection for ADC I/P P-terminal',0
Capabilities: enum
Item0: 'off'
Simple mixer control 'MIC1RP selection for ADC I/P P-terminal',0
Capabilities: enum
Item0: 'off'
Simple mixer control 'Program Registers',0
Limits: 0 - 65535
Mono: 0 [0%]
Simple mixer control 'Right DAC Mute',0
Capabilities: enum
Item0: 'Unmute'
Simple mixer control 'Right DAC input selection',0
Capabilities: enum
Items: 'off' 'right data' 'left data' '(left+right)/2'
Item0: 'right data'
Simple mixer control 'Right Output Mixer DAC_R To HPR Driver swit',0
Simple mixer control 'Right Output Mixer DAC_R To Right Mixer Amp',0
Mono: Playback [on]
Simple mixer control 'Right Output Mixer MIC1RP To Right Mixer Am',0
Simple mixer control 'SP Analog Gain Volume(0=0dB, 127=-78.3dB)',0
Limits: 0 - 127
Mono: 127 [100%]
Simple mixer control 'SP Class-D driver Volume(0=6dB, 4=24dB)',0
Limits: 0 - 0
Mono: 0 [0%]
Simple mixer control 'SP driver mute',0
Mono: Playback [on]
Simple mixer control 'Throughput of 7-bit vol ADC for pin',0
Limits: 0 - 7
Mono: 0 [0%]
An insane amount of options for just a beeping device.
(for reference, this is what my laptop can do: full stereo, record, playback, synthesize, the whole shebang:)
[marcelr@laptop46 ~]$ amixer
Simple mixer control 'Master',0
Capabilities: pvolume pswitch pswitch-joined
Limits: Playback 0 - 65536
Mono:
Front Left: Playback 22917 [35%] [on]
Front Right: Playback 22917 [35%] [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch cswitch-joined
Limits: Capture 0 - 65536
Front Left: Capture 11310 [17%] [on]
Front Right: Capture 11310 [17%] [on]
Anyway, will try to make some sense of it and get the beeps going
