Toon app: Afvalwijzer
Re: Toon app: Afvalwijzer
gerlag wrote: Tue Aug 02, 2022 9:45 am Hi, it seems that castricum moved to another site: mijnafvalzaken.nl which is not (yet) in the list. Until a few weeks ago it was mijnafvalwijzer.nl.
Could mijnafvalzaken.nl be added?
I added mijnafvalzaken.nl (provider 51).
- go to the settings screen of the app and select provider 51
- enter your calendar ICS nr in the settings screen
On your PC go to the mijnafvalzaken.nl and login with your zipcode/housenr.
Find the download link for your calendar (usually via de button 'Zet inzameldata in agenda' or something similar).
The last 16 digits of the link is your ICS nr (example: webcal://mijnafvalzaken.nl...... 0000016317)
Press 'Opslaan' on Toon after entering the ICS nr. Toon will download the new plugin and restart once to activate it.
Kind regardz,
a3vd wrote: Wed Aug 03, 2022 10:22 am I want to change some icons on my rooted toon2
Is there any restriction on the used icons ?
Colour depth / transparency ? :?:
I edited an existing icon in Adobe Photoshop and saved it as png but it was not visible :shock:
Which icon do you want to change?
gerlag
Post by gerlag »
Toonz wrote: Thu Aug 04, 2022 6:45 pm [..]The last 16 digits of the link is your ICS nr (example: webcal://mijnafvalzaken.nl...... 0000016317)
Kind regardz,
Thanks a lot. Tried it, it works like a charm!
nick1984
Post by nick1984 »
Since a week of two stopped my toon to show the icons..
And it shows the wrong discriptions, like "onbekend"/"Groot vuil". Only PMD is still working?
Afvalverwerker: 41 RadBV
this is the link to the ICS file
https://wasteprod2api.ximmio.com/api/Ca ... ln=nl&nt=7
I think RadBV changed something but i don't know what.
Can you help me with this problem?
Kind Regards,
Nick
nick1984 wrote: Wed Sep 21, 2022 9:09 am Since a week of two stopped my toon to show the icons..
Kind Regards,
Nick
They changed the waste descriptions, I have updated the plugin.
If you go to the settings screen of the app on Toon, the new plugin will be downloaded.
I made these changes online (not tested myself).
Let me know is something is wrong/missing.
KInd regardz,
nick1984
Post by nick1984 »
Hi Toonz,
Thank you for you're quick reply. Every think works again!
Kind Regards,
Nick
wolter72
Post by wolter72 »
Can you please add afvalkalender.defryskemarren.nl to this app for my parents.
Thanks in advance.
wolter72 wrote: Sat Nov 05, 2022 1:54 pm Hello,
Thanks in advance.
This one is quite different from all others I've seen so far. Will require a bit of programming.
Will do but can take a few days.....
Thanks in advance.
That was quicker than I expected.
You can now select provider 52 (defryskemarren.nl) and enter your ICR Nr.
I just tested with a random zipcode in Terherne, let me know if the descriptions are not correct in your village.
How to get your ICS Nr:
1. On your PC goto https://afvalkalender.defryskemarren.nl/ and login with your zipcode/housenr.
2. goto https://afvalkalender.defryskemarren.nl/wanneer
3. Click on the button 'Zet in Agenda'
4. The ICS Nr are the last 16 digits of the URL to your calendar
Enter this number on the Toon in the 'Instellingen' page of the Afvalwijzer app and press 'Opslaan'.
Kind regardz,
wolter72
Post by wolter72 »
Thanks for the quick response.
pjottertie
Post by pjottertie »
Goedemiddag, ik ben hier nieuw en heb pas een geroote Toon 2 gekocht en ben zelf wat aan het instellen geweest. Nu krijg ik mijn afvalkalender niet draaiende, ik woon in Werkendam. Alvast bedankt.
Bruce the boss
Post by Bruce the boss »
Hallo, zijn er meer mensen bij wie de afvalwijzer niet meer werkt? Postcode 5527........
Bruce the boss wrote: Sun Dec 25, 2022 2:13 pm Hallo, zijn er meer mensen bij wie de afvalwijzer niet meer werkt? Postcode 5527........
HIj doet het nog wel, echter laat hij alleen de ophaaldata zien van het huidige jaar.
En helaas zijn er geen ophaalmomenten meer dit jaar voor jouw gemeente.
Als het goed is vult de kalender zich vanzelf weer in het nieuwe jaar.
Fijne jaarwisseling :-)
pjottertie wrote: Sat Dec 10, 2022 4:01 pm Goedemiddag, ik ben hier nieuw en heb pas een geroote Toon 2 gekocht en ben zelf wat aan het instellen geweest. Nu krijg ik mijn afvalkalender niet draaiende, ik woon in Werkendam. Alvast bedankt.
Ik heb zojuist de gemeente Altena toegevoegd.
Ga naar het instellingen scherm van de Afvalkalender app. Vul in afvalverwerker 53, vul vervolgens je postcode, huisnummer in en druk op 'Opslaan'.
De Toon zal na 10 seconden op nieuw opstarten met de nieuwe module voor Altena.
Kind regardz,
Blacky's Boss
Post by Blacky's Boss »
Toonz wrote: Mon Dec 26, 2022 12:37 am
hmmmmm, leeg. En mijnafvalwijzer.nl laat wel info zien voor 3863GE....
