Toon app: Afvalwijzer
Rudolf
Re: Toon app: Afvalwijzer
Post by Rudolf »
Toonz wrote: Tue Jun 27, 2023 8:59 pm
Rudolf wrote: Tue Jun 27, 2023 8:36 pm This is amazing! And so fast too.
Does the app require an update, 33 isnt a valid/documented choice anymore, is it?
So, just go the settings screen and select option 33 again (if you already had option 33 it will tell you that there is an update I believe).
P.S. if you had already 33 and it is not updating, then I didn't increase the version number correctly.
In that case select another option first and after reboot switch back to 33 as a workaround.
P.P.S and you need to enter your zipcode/housenr now....
Thanks! That did the trick.
It seems like the calendar offers both Restafval and PBD, but that's quite redundant since there's no separate pickup anymore.
I think I managed to filter out this specific type (1) with a quick hack in the Provider.js
Am I the only one with this need? If not I might be able to come up with a more elegant solution and open a pull request.
Rudolf wrote: Wed Jun 28, 2023 7:28 pm
I updated the version number and removed some debug log statements so the new version will be used by all (sorry Rudolf but this will overwrite your manual changes).
I see that Restafval and PBD are collected together but through the API I get these reported as 2 separate events.
Flashlab
Post by Flashlab »
Hi Toonz,
For me the omrin.nl plugin stopped working after I updated the omrin.htm file. I tried reinstalling the Afvalwijzer app but no luck so far...
I am on holiday without a Toon 😁.
Can you try as workaround provider 33? Maybe it works with your zipcode/housenr.
If not, I wil have a look when I am back
Flashlab
Post by Flashlab »
Just back from my own holiday ;-)!
And happy to report that 33 works! Even better as I don't need to manually upload the html file any longer.
Thank you Toonz and enjoy your holidays!
Denace112
Post by Denace112 »
Beste Toonz,
Dank voor je mooie app! Ik heb alles gedaan zoals ik dacht dat het moest maar zie helaas nog geen afvaldata.
{"Afvalverwerker":"16","CreateICS":"No","CustomIcons":"No","DisplayIconVanafUur":18,"ExtraDatumsFile":"","ExtraDatumsIconsFolder":"","Gemeente":"Lisse","Huisnummer":"10","ICSUrl":"https://wasteapi2.ximmio.com/api/CallIc ... yIcon":"No"}
Heb jij nog tips?
bulldogbob
Post by bulldogbob »
Hallo allen,
Heb sinds gisteren Toon v2 rooted en wilde graag gebruik maken van de afval app. Ik zie gemeente Tiel niet in de lijst van de app. Ik las hier dat het vuilverwerker 25 was, maar dat klopt niet meer. Kan iemand mij verder helpen.
bulldogbob wrote: Wed Aug 30, 2023 9:27 am Hallo allen,
Je kan afvalverwerker 33 kiezen voor Tiel.
Groeten,
Denace112 wrote: Wed Aug 16, 2023 10:13 am Beste Toonz,
Heb jij nog tips?
Lijkt op zich ok, werkt hier ook.
Als alternatief kan je ook provider 33 kiezen (met postcode/huisnummer), die werkt ook voor Lisse.
cootjec
Post by cootjec »
Beste App designers,
Ook in de provider 40, spaarnelanden.nl is de omschrijving "onbekend" beschreven in de display van TOON ipv "Duocontainer PBD/Papier"
Is dat mogelijk dat dit kan worden aangepast ?
webcal://afvalwijzer.spaarnelanden.nl/ical/0392200000055782
omschrijving "Gft en etensresten" wordt wel vertaald naar " Groenten/Fruit/Tuinafval" in het display
Alvast bedankt
update:
Met provider 33 is deze mismatch er niet, ik gebruik voorlopig provider 33, thanx
cokleiden
Post by cokleiden »
Hallo
gemeente Leiden heeft geen link waar kan ik vinden . :shock:
cokleiden wrote: Tue Sep 26, 2023 7:11 pm Hallo
Klopt, die geven geen downloadlink.
Gelukkig kan je wel afvalverwerker 33 kiezen in de instellingen van de app en je postcode/huisnr invullen
cootjec wrote: Fri Sep 22, 2023 12:01 pm Beste App designers,
Alvast bedankt
update:
Afvalverwerker 40 werkt ook weer (wel even de nieuwe plugin ophalen door naar het instellingenscherm te gaan)
MastaG
Post by MastaG »
Hi, ik heb sinds kort onze Toon geroot en de afvalwijzer plugin geïnstalleerd.
Het lijkt er alleen op dat plugin nummer 14 voor rova.nl (gemeente Amersfoort) niet werkt.
Althans ik heb het geprobeerd met huisnr 10A en met alleen nummer 10.
In beide gevallen wordt er geen info opgehaald.
Ik ben ook even door het lijstje heen gegaan, maar volgens mij deelt Rova geen data met andere partijen als het om de afhaal calender gaat.
Kan je provider 33 eens proberen met je postcode huisnr?
