I'm using the temperatures to check the delta T and the general performance of the furnace.
So thanks for the tip to downgrade thermstat
![Smile :)](./images/smilies/icon_smile.gif)
Does anybody know if this also works for the Toon2?mennozon wrote:I've downgraded only the thermstat application by downloading the version I previously used, this seems to work but I only tested it for a day so please be aware that things might be broken by doing this.mogwai wrote: So if you guys see any option to revive this functionality without downgrading this would be highly appreciated!
So far everything seems okay (I can read boiler temperatures again and I have heating working) but the binary increased more than 4 times from the previous version, makes you wonder what they've all changed..
Steps I've used were enable VPN with the update-rooted script, wget the file, let opkg downgrade it and reboot.
sh update-rooted.sh -o wget http://feed.hae.int/feeds/qb2/POOL/happ-thermstat_1.2404-master_qb2.ipk opkg --force-downgrade install happ-thermstat_1.2404-master_qb2.ipk
wget http://feed.hae.int/feeds/nxt/POOL/happ-thermstat_1.2404-master_nxt.ipk
opkg --force-downgrade install happ-thermstat_1.2404-master_nxt.ipk
nope doesn't work on a toon2, maybe I need another file, does someone know that?Fietspomp wrote:Does anybody know if this also works for the Toon2?mennozon wrote:I've downgraded only the thermstat application by downloading the version I previously used, this seems to work but I only tested it for a day so please be aware that things might be broken by doing this.mogwai wrote: So if you guys see any option to revive this functionality without downgrading this would be highly appreciated!
I use the values for my home assistant to switch on/off my floorheating pump!
To answer my own question:Code: Select all
sh update-rooted.sh -o wget http://feed.hae.int/feeds/nxt/POOL/happ-thermstat_1.2404-master_nxt.ipk opkg --force-downgrade install happ-thermstat_1.2404-master_nxt.ipk
qb-659916001601-1914A0BTRR:~# opkg --force-downgrade install happ-thermstat_1.2404-master_qb2.ipk
Not selecting happ-thermstat 1.2404 due to incompatible architecture.
Package happ-thermstat (1.2413-master) installed in root is up to date.
I think you need this one: happ-thermstat_1.2404-master_nxt.ipkgielie wrote: nope doesn't work on a toon2, maybe I need another file, does someone know that?Code: Select all
qb-659916001601-1914A0BTRR:~# opkg --force-downgrade install happ-thermstat_1.2404-master_qb2.ipk Not selecting happ-thermstat 1.2404 due to incompatible architecture. Package happ-thermstat (1.2413-master) installed in root is up to date.
NO, I can't download this fileglsf91 wrote:Ik denk dat je deze moet hebben: happ-thermstat_1.2404-master_nxt.ipkgielie wrote: nope doesn't work on a toon2, maybe I need another file, does someone know that?Code: Select all
qb2 is for Toon 1 and nxt for Toon 2.gielie wrote: NO, I can't download this file
yes it works, I forgot to open the tunnel again, tanksglsf91 wrote:qb2 is for Toon 1 and nxt for Toon 2.gielie wrote: NO, I can't download this file
Did you try the part Fietspomp wrote ?Code: Select all
Did you update the firmware of Toon?Jasper wrote:2 days ago it started showing Nan for boiler in and out temp, anything I can post here to get it fixed?
I thought I did that last week though might be later then I thought.glsf91 wrote:Did you update the firmware of Toon?Jasper wrote:2 days ago it started showing Nan for boiler in and out temp, anything I can post here to get it fixed?
If yes, read previous posts in this topic. It won't work anymore after a specific version
Read the last 3 pages of this topicJasper wrote:glsf91 wrote:Can I go back to a working version or not?Jasper wrote:2 days ago it started showing Nan for boiler in and out temp, anything I can post here to get it fixed?
