Is this supposed to work on Toon2 as well?
For me it doesn't.
Quite recently moved my HomeAssistant to another machine and create a config_ file for pairing to Toon. This works fine for Toon1, but not for Toon2.
Manual: Domoticz devices to Toon (HA-Bridge solution)
- Administrator
Re: Manual: Domoticz devices to Toon (HA-Bridge solution)
Dont know to be honest.Rudolf wrote:Is this supposed to work on Toon2 as well?
For me it doesn't.
I'm not using the HA-bridge myself. Well actually im not using the Toon2 either (HomeBridge + Domoticz = Siri assistant )
Hello Rudolf,
I setted up the bridge on a raspberry (the same which domoticz is working), with the description in the first post of this topic.
And i managed to get it working on my toon2 with the discription in viewtopic.php?f=87&t=11777&p=83254#p83254
I manually editted the config_hdrv_hue.xml file to force my toon to see the bridge.
Thsi configuration is working for me, on my toon2.
Maybe it helps you.
Maybe it helps you.
Thanks for sharing; glad to hear the config-file-mod should still work. I'll try again.
Thanks again; works like it should! Toon2 seems to be more picky with the first MAC-address; Toon1 didn't care about an error I made. Toon 2 did.
