PLC2220 & LED & 3 Phase Coupler
Posted: Fri Jun 13, 2008 9:56 am
Is there an option to use a 2220 with LED lighting?
Is there a possibility to DIM the LED lighting or will it then be lightNing[V]?
Can someone also tell/show me in a diagram how to install the 4825 (3 Phase Coupler) can I put this direct behind the 3 current-leak devices (each fase has a separate current-leak breaker at my home).
