Temperature sensor fridge
Posted: Sat Sep 30, 2017 4:47 pm
by DJF3
Team,
I'm looking for a temperature sensor with external sensor for my freezer.
Is there anything rfxcom compatible for sale right now? (In the Netherlands)
Cheers
DJ
Re: Temperature sensor fridge
Posted: Sun Oct 01, 2017 11:52 am
viewtopic.php?f=27&t=2202&p=15161&hilit=thc138#p15161
lots of them not available anymore thc238 should be the successor, but also hard to find
I use the thc138 which works fine, but they are older now
Posted: Sun Oct 01, 2017 11:54 am
by b_weijenberg
Posted: Sun Oct 01, 2017 3:53 pm
by DJF3
Dag Bert,
Is this device not supported on the RFXLAN?
Posted: Sun Oct 01, 2017 6:30 pm
by b_weijenberg
RFXLAN supports only Oregon sensors.
You can use the internal sensor of an Oregon sensor and extend the connection with a thin 2-pair cable. Isolate the sensor with a 2 cm heat-shrink tube.
Posted: Sun Oct 01, 2017 7:17 pm
by Rutger
I've an Oregon sensor just IN the fridge, after 1,5 years no issues so far.
Posted: Sun Oct 01, 2017 8:13 pm
by DJF3
Rutger wrote:I've an Oregon sensor just IN the fridge, after 1,5 years no issues so far.
The signal doesn't reach my rfxcom from within the fridge
Will try Bert's suggestion to extend the sensor itself. I may have to calibrate it after taking it out of the original casing
Posted: Tue Oct 03, 2017 2:34 pm
by DJF3
b_weijenberg wrote:RFXLAN supports only Oregon sensors.
I opened a typical (simple) Oregon temp sensor. WOW!
The wires going to the temperature sensor are as thick as a
hair!
Not sure I can extend that with my soldering
