(SOLVED) Raspberry pi MQTT problems
rsluiman
Post by rsluiman »
I've been having the OTGW running for over a few months and wanted to try something more with it.
I've got a raspberry pi and downloaded the otmonitor specific for the pi.
The problem i'm now facing is that when i enable mqtt the checkbox won't get enabled. to solve this i tried the web interface.
After enabling mqtt in the web interface i get the folowing error from otmonitor:
invalid command name "mqttmessage"
    while executing
"mqttmessage $src"
    (procedure "otmessage" line 5)
    invoked from within
"otmessage [clock microseconds] $line [expr {$type & 7}] $id $data"
    (procedure "process" line 12)
    invoked from within
"process [append data $line]"
    (procedure "receive" line 6)
    invoked from within
"receive"
this is probably a problem in the source code but i got no experience with tcl code but i can program in other languages so if you guys can point me in the right direction i might be able to solve this myself
mike7
Re: Raspberry pi MQTT problems
Post by mike7 »
Please show mqtt settings from .otmonitorrc, I'll try to help
PS. mqtt definitely working in otmonitor
rsluiman
Post by rsluiman »
the mqtt settings in the settings file
mqtt {
  devicetype central_heating
  deviceid otmonitor
  retransmit 10
  format json2
  port 1883
  qos 1
  keepalive 120
  username admin
  password YWRtaW4=
  enable false
  messages false
  client raspberryPiHub-otmon
  broker 192.168.0.110
mike7
Post by mike7 »
looks good, the only difference from my setup:
I don't use authentication
  username {}
  password {}
  enable true
you can try to enable mqtt directly in the settings file
rsluiman
Post by rsluiman »
I'm getting the same result as enabling trhough the web interface
mike7
Post by mike7 »
strange, looks like otmonitor doesn't read or reads wrong settings file
could you try to use -f command line switch like
./tclkit.ahf otmonitor.vfs/main.tcl -f /home/pi/.otmonitorrc --daemon --system -w 8080
I'm using source version, you can change command for single file version
rsluiman
Post by rsluiman »
What makes you think it doesn't read the config? everytime i start otmonitor it reads and writes the config correctly the problem here is i think in the source code
mike7
Post by mike7 »
I found
enable false
in your settings file, if it is enabled and doesn't work try to connect without authentication.
rsluiman
Post by rsluiman »
I've been digging through some tcl tutorials as well as the source code. you need libmposquitto installed on the pi for it to work. after installing this it works
mike7
Re: (SOLVED) Raspberry pi MQTT problems
Post by mike7 »
Could you please explain what you did?
I'm using Arch Linux and mosquitto is not installed (I'm using mosquitto in container).
As I understand otmonitor is using mqtt module from lib/tcl8/8.6/mqtt-1.0.tm
