Toon app: Dashticz (no longer working)
Locked
atlantica
Re: Toon app: Dashticz (for Toon); NEW: OV Info (NL)
Post by atlantica »
What editor do you use? Try to use vi for editing...
Regards
David
mAiden
Post by mAiden »
atlantica wrote:What editor do you use? Try to use vi for editing...
Dont like vi, i have always a fight with it.. I use WinSCP on Windows, you can edit also with it. Or i use nano on Linux to edit, Toon dont have nano onboard. :)
richardklasens
Post by richardklasens »
I tried to install today on my freshly Rooted toon.
SW 5.0.4.
Edited the DomoticzBoardApp.qml for my IDX numbers.
Then send it thru my toon with SFTP.
Rebooted
I have a Lightbulb on the tray... Check
When i opened the Domoticz screen on Toon i have 8 Grayed Squares without png's or names.
The grayed squares are connected to my IDX numbers and they work.
So only the Visual section isn't working.
I've checked a few lines of code in DomoticzBoardApp.qml and find out that the names of the PNG files don't match with the png's in the Drawables folder?
Any solutions?
RobbieT
Post by RobbieT »
richardklasens wrote:I tried to install today on my freshly Rooted toon.
SW 5.0.4.
Rebooted
Any solutions?
I got this problem to but find out that i actually used a wrong username/password. Can you tell me what your domoticz log is showing? And did you converted the username and password to base64?
mAiden
Post by mAiden »
You need to wait for the next update, pngs and images are not in the resourcefile now..
phoenixb
Post by phoenixb »
Because the DomoticzBoard and Dashticz app is both writed in this topic I want to know if the Dashticz app is still working in the latest Toon version?
__________________
Hypermobile
Post by Hypermobile »
Dashticz: Nope not available anymore in 5.13.9 :-(
@least i don't see the icon anymore on the top...
switching to domoticzboard...but the amount of switches is limited
Blacky's Boss
Post by Blacky's Boss »
Yes, but you are completely free to choose which switches you want. Dashticz only showed favorites. Can you guess what my favorites are?
Correct. All information from Toon... Makes a nice dashboard in the app.
ArieKanarie
Post by ArieKanarie »
Now that dashticz is not working properly, what is the right & complete way to remove the app from my toon, since it is not installed through the appstore/
ArieKanarie wrote:Now that dashticz is not working properly, what is the right & complete way to remove the app from my toon, since it is not installed through the appstore/
simply remove the folder dashticz from the folder /qmf/qml/apps
ArieKanarie
That is easy :)
Thanks.
retroscoot
Post by retroscoot »
hello,
is this working?
i got some trouble..
i have place it into the right map on the toon.
but i needed to edit this file '/HCBv2/qml/qb/base/Globals.qml' but i dont have that file...
got an rooted toon from markplaats. and new into it...
greetz
mAiden
Post by mAiden »
retroscoot wrote:hello,
is this working?
greetz
Dashticz will not work on the last version. You can't edit globals.qml anymore, this file is hidden in the resourcefile.
You can download DomoticzBoard.
TerrorSource
Post by TerrorSource »
Topic closed due to inactivity from the developer while app is in need of an update.
Please send me a PM if you want to continue to develop this app
Locked
