I'm trying the connect the meteradaptor to my Toon.
No connecting, even not at 10 cm.
Is there a way to reset meteradaptor ?
Meteradaptor unable to connect
Re: Meteradaptor unable to connect
yes, in the same menu where you add the adapter, you can choose advanced and then repair/reset the adapter (somehting like that). It is probably registered to another Toon (or old config or something). So it first needs to be de-associated from that using the repair/reset instruction.
I did, and then it is connected,
but when I go back to the home screen, the connect is lost again ,
Can you theck the output of your: "http://[toon-ip-address]/hdrv_zwave?action=getDevices.json"jossie67 wrote:I did, and then it is connected,
That will show all your zwave devices, like the meteradapter. Maybe there is another meteradapter in there but not registered correctly. You can remove all devices somewhere in an advanced setting. Also check the repeaters-advanced button.
I remove alle devics
this is the output
{"dev_settings_device": {"uuid": "eneco-001-141971:hdrv_zwave_67723C6C675", "name": "settings_device", "internalAddress": "settings_device", "type": "settings_device"}}
this is the output
I found the solution to my issue.
After rooting my Toon, I connected to Zwave antenne on the wrong connector
this is the wrong connector
Beside the Zware chip is the connector for the Zwave antenne
