I have owned a Toon for about 5 years now, 2 years ago I ended my contract with Eneco and also ended the Toon subscription. Rooting has been on my wish list for some time and finally I rooted my Toon (on version 4.18.8 ) earlier this week and this forum has been a great source of information. I started looking at the (picture) overview of functionality and what I could find myself and what I need a bit of help with. Because not all of it is obvious.
Hopefully people can add to this , I will then edit this post and add new information if it pops up.
This is the list with my comments/summary/findings.
- Manual control of the thermostat.
Obvious - Control Toon from a distance(smartphone or tablet)
The options are:
* An android toon app (Supports hacked Toon) as described here:android app TOON
* Download and install X11VNC as described here:Remote control of your Toon through VNC (but not that obvious for a phone)
* Web proxy to control Toon remotely
* Controlling Toon via Domoticz - Power usage today
I did nothing to enable this, it is just there. But can it be enabled/disabled? - Gas usage today
I did nothing to enable this, it is just there. But can it be enabled/disabled? - Historical power usage in Graphs
- Historical Gas usage in Graphs
The config file, config_happ_scsync.xml is mentioned here: Useful files explained.
Use a valid end date and set GasDisplay. ElectricityDisplay (for Graphs etc) and ProductVariant to get all tilesCode: Select all
<EndDate>1627485995</EndDate> <ProductVariant>Toon</ProductVariant> <ElectricityDisplay>1</ElectricityDisplay><GasDisplay>1</GasDisplay>
- Power and Gas costs using actual tarifs
Not possible at the moment. - Usage stats compared to estimated usage per year
Not possible at the moment. - Compare usage to other Toon users
Not possible at the moment - Control other devices from a distance and find energy consumers using smart plugs
(no comment- did not look into this) - Connect smokedetectors to toon
(no comment- did not look into this) - Sun on Toon
As described here: ZonOpToon alternative a correct 'meteradapter' (the old meteradapters don't work with ZonopToon)is needed. Next to that you need a kWh meter counting the production and providing the led pulse output. Or you can make something yourself (out of scope of this forum) which provides pulses..
How to switch on is described in: Useful files explained. In config_happ_scsync.xml change "SolarDisplay" and "SolarActivated" to 1 - Insights in boilerparameters
* First install the Toon Store app (if not already installed):
** Download the Toon Store app
** Transfer it to Toon using e.g. WinSCP
** Log in to Toon and install Toonstore:** Replace resource file if version > 14.16.8 Download here, described here: Toon firmware resource file (as from 4.16.8 )Code: Select all
opkg install toonstore_1.1.4-r0_qb2.ipk (or later version)
** Restart Toon using: killall qt-gui
* Install the Boiler status app using Toon Store. - Temperature trends during the day
* Install Temperature Logger - Kodi media support
Toon app: Kodi media player - Control toon from a distance (PC)
Remote control of your Toon through VNC - Automatically scroll through tiles
Described here: Toon app: rotating through tiles, automatically - Waste collection display
* Install Waster Collection app using Toon Store - Backup of energy data
I did find this thread on backup, not sure if there is a way to back-up energy data only.
Automatic remote backup of Toon files - Rollback updates
Not possible but official updates can be retrieved and installed.
Choose any version using this script as described here: Toon firmware - update script - Complete domoticz control
Controlling Toon via Domoticz - Sonos speaker control
* Install Sonos app using Toon Store
- I see this mentioned: http://<ip-of-your-toon>/happ_thermstat?action=getThermostatInfo. where can I find an overview of apps and possible actions? Which files contain this information
- I see mention of MQTT and that Toon has it onboard already, sounds promising...
