Popp thermostat z-wave POPE010101
Posted: Fri Oct 19, 2018 3:55 pm
by Wim2008
I like to buy a or more Popp radiatorthermostats POPE010101 this month.
See www.popp.eu/thermostat/
Is there someone who has experience with this Popp thermostat z-wave or someone who knows something from this thermostat?
I use HS3 version 3.0.0.435 and the pluginn z-wave version 3.0.1.190 at windows 7.
My z-wave devices at home are connected with the Aeon z-stick or with the Gen 5 stick. No problems at all the last 2-3 years.
Kind regards Wim
Re: Popp thermostat z-wave POPE010101
Posted: Sat Oct 20, 2018 11:37 am
by Akatar
I don't know this popp thermostat and i have no idea if it's going to work with homeseer
other options are:
fibaro thermostat valve (no idea if it works with hs3)
or
honeywell evo home (there are a couple of plugins that work with the evohome series
Posted: Sat Oct 20, 2018 11:55 am
by Wim2008
Thanks for your reaction.
Do you know something about the Danfoss LC13?
Wim
Posted: Sat Oct 20, 2018 12:02 pm
by Akatar
No, i have only honeywell evohome. but i will test the fibaro thermostat valve in a couple of weeks.
You can buy whatever you want, i guess if it doesn't work you can sent it back to the webshop?
Re: Popp thermostat z-wave POPE010101 or Danfoss LC13
Posted: Sat Oct 20, 2018 12:13 pm
by Wim2008
Ok.
My thought was, if there are people using or had used those thermostats, perhaps it is possible to get info about them, before I buy those thermostats.
I also heard from someone that the Popp thermostat is a newer version of the Danfoss LC13 thermostat. ALso the Popp thermostat has newer and more stable firmware.
See also http://www.domoticaforum.eu/viewtopic.p ... c13#p77674
Wim
