Hi m another new one
made me myself a wood demobord with a HCB 2x imx10 1x zax12 1x daix12 1x saix12 m trying to get my daix12 to dim on the imx10 nou that doesnt seem to work try'd to read all manuals but couldnt find something.. the imx10 is ment to work on a 2x2 pulsdrukker that means puls up = on puls up again=brighter puls down=lesser light and then off.
aneyone can help me whith tis .. ??
thxs
Xanura dim
Xanura dim
Should be easy. Did you give the IMX10 the same address as the DIAX12?
How do you program them?
Xanura dim
no i did not give them the same adress... should i ?? programmed them in the hcb v1.4 loose of each other.
tryed to make a macro etz its possible but the and or thing is getting quit huges then
Xanura dim
ur awnser was enough to make it work thxs m trying possibilities on bord to make an effective home system in once but have no experience on xanura
