Programming reference
SDeath
Post by SDeath »
Where do you find the documantation of the programming language the Toon uses, I tried in the QT documentation but it is of no real help.
i.e. I am looking for all possible options of the "qnumKeyboard.state = ", where can I find it?
There must be something available as to what is possible and the correct formats and options.
Toon1 running firmware 5.33.9 (rooted)
Re: Programming reference
You don't find that anywhere unfortunately.
Quby hasn't been so kind to share their sources and programming standards :-).
So, it is basically all 'reverse engineering' by looking at the Quby (QML) code and other ToonStore apps, combined with the public QT documentation.
SDeath
Post by SDeath »
So is there any old Quby QML code available somewhere?
All apps are now encrypted so I can't see anything from them.
Right now I'd like to use qnumKeyboard and by looking at Afvalwijzers code I can see some but I'm guessing some of the other options.
This is a bit of a waste of time.
Also it isn't even mentioned in the QT documentation when I do a search.
Post by TheHogNL »
Good question. I have just created an unpacked version of the 4.22.7 (by tsc modded) resource file for everyone to download: http://qutility.nl/resourcefiles/qb2-4.22.7.zip
SDeath
Post by SDeath »
That will help I'm sure.
Thanks TheHogNL!!
