Yesterday I did installed my rooted Toon1 and some Neo Coolcam Powerplugs.
Now I have the following problem:
I did allowed in "Instellingen"- "Internet"- "Allow for 2 hours" and saved
I have the ip adres 192.168.2.20
If I open this in Firefox I will get error 404 - Not Found
Do i forget something or do I need to do something extra?
Toon is not opening on laptop
- Starting Member
Toon 2 Rooted User
Firmware version: 5.94.7
Raspberry Pi 3B+
Domoticz 2022.1
10 Neo Coolcam PowerPlus
Domotica Beginner (need little help in beginning)
Raspberry Pi 3B+
Domoticz 2022.1
Re: Toon is not opening on laptop
If you followed the rooting guide you don't need to open the toon from the GUI.witteherder wrote:Hello,
Check your /etc/default/iptables.conf if you opened port 80.
And also check /qmf/etc/qmf_release.xml if you alloweda all urls ( enforceWhitelist on 0)
- Starting Member
Can you help me to do that please?If you followed the rooting guide you don't need to open the toon from the GUI.
I assume it's not in my Firefox to open but with another program?
Toon 2 Rooted User
Raspberry Pi 3B+
Domoticz 2022.1
Raspberry Pi 3B+
Domoticz 2022.1
Please follow this guide: https://ehoco.nl/rooten-van-enecos-toon-thermostaat/
If you can't figure that out either, please understand that rooting a Toon requires some linux skills and requires you to understand what you are doing.
- Administrator
What do you want to do? You cannot open a website on the Toon to control the temp. You need to do that via http-api-calls.TheHogNL wrote:If you followed the rooting guide you don't need to open the toon from the GUI.witteherder wrote:Hello,
What you try is not much more than just a zwave page that you can not do much with.
What do you want? Maybe we can help you with it, on the right way
I fyou install the 'old' quby webserver on your Toon then is wil work just nice in a browser
viewtopic.php?f=102&t=11832&hilit=mobil ... =45#p86593
- Starting Member
I want to control it wirh Domoticz
Toon 2 Rooted User
Raspberry Pi 3B+
Domoticz 2022.1
Raspberry Pi 3B+
Domoticz 2022.1
