Toon 2 questions
If you don't know where to post, post here.
HansS
Toon 2 questions
Post by HansS »
Hi! I just received my TSC modified Toon 2. Seems that my own custom apps are working, although the icons are not transparent, but I will look into that later.
I have a couple of questions though:
- I cannot install the sftp server package, because it says wrong architecture. Is there an sftp server package for the new Toon?
- My Toon says that it is connected to the Service Center, although ovpn is commented in /etc/inittab. I don't have a subscription, so I would rather not be connected to Eneco. Should I disconnect it some other way?
- I would like to use TigerVNC to remotely view Toon. Is that possible?
Thanks!
Re: Toon 2 questions
HansS wrote:- My Toon says that it is connected to the Service Center, although ovpn is commented in /etc/inittab. I don't have a subscription, so I would rather not be connected to Eneco. Should I disconnect it some other way?
It isn't connected. We fake this in the resourcefile to surpress the annoying notifications on Toon that you are not connected to the SC.
HansS wrote:I would like to use TigerVNC to remotely view Toon. Is that possible?
Only for looking at the screen, not for operating it.
This is because the new Toon is using a multi-touch screen which is not yet supported by VNC.
It is on our to-do list and might become available in due course.
Kind regardz,
HansS wrote: - I cannot install the sftp server package, because it says wrong architecture. Is there an sftp server package for the new Toon?
I'm working on it, find it quite annoying myself as well.
Post by TheHogNL »
sftp is not needed... the dropbear (which provides SSH) also provides scp.. just use winscp if you want to transfer using windows or scp from a linux device
Doesn't really work in my microsoft-free environment ...
Done. It's here:
http://files.domoticaforum.eu/uploads/T ... p-neon.ipk
Upload and install. Works out of the box.
WickedMaster
Post by WickedMaster »
marcelr wrote:Done. It's here:
Nice, I was also looking for it. Does this one also work on Toon 1? Or do we still use the old one.
Nope, this is for a different architecture. The sftp server for the older toons (pre FW 5.0.4) is here:
http://files.domoticaforum.eu/uploads/T ... .0_qb2.ipk
It needs a rebuild for the newer FW on toon 1.
Post by TheHogNL »
marcelr wrote:Doesn't really work in my microsoft-free environment ...
As I said, on a linux native device just use SCP :-)
But no, you probably want a window like GUI and not a command line tool ;)
Filezilla, to be exact :-)
You know my typing skills ...
HansS
Post by HansS »
Thanks for getting sftp working, that was fast! ;)
I'm also on non-windows, and indeed using Filezilla.
Nice job on the modification and the TSC menu by the way. Also, I got the Toon Store, never used it before, but working nicely.
Another thing (there might be more), I was using https://github.com/jonkootje/toon-app to control Toon from my phone, but it seems that /happ_thermostat is no longer there. Did you guys come across this yet?
<Update> Is there a download for x11vnc for Toon 2? The one in the downloads section is wrong architecture </Update>
... and sftp-server for toon1, FW 5 and later:
http://files.domoticaforum.eu/uploads/T ... armv5e.ipk
enjoy.
WickedMaster
Thanks! But the old one was also working fine here, on 5.0.4.
Could be, didn't check for dependencies. Anyway. this one should function as well ...
HansS
Post by HansS »
Is there also a cron package for Toon2?
Return to “Toon miscellaneous”
