For example quite often it's mentioned that device polling should be avoided if possible and if used the value should be increased. Disable the polling typically doesn't provide any problem, just that a few Qubino's on my side might turn red if they haven't been utilised for a while. Enabling will increase the zwave mesh network traffic and therefor the polling value should be increased. I've set it to 60s and I have 15 devices. Any recommendation here based on the number of zwave devices vs poll time?
Another parameters which seems essential to make use of is the, security network key, but on the other hand, quite often it's recommended not
Any other suggestion which of course might be different based on whether one have 5,10,20,30 or more devices?
