Page 1 of 2
Rooted Toon: Homey support?
Posted: Mon Mar 11, 2019 11:26 am
by mbnn
I was wondering, is there a way to make Toon (Rooted) work with Homey?
I suppose the app for Homey only works with a Eneco subscription based Toon?
Is there any other way to make them talk to eachother?
Thanks.
Re: Rooted Toon: Homey support?
Posted: Mon Mar 11, 2019 2:57 pm
by TheHogNL
https://ifttt.com/homey
You can connect homey to ifttt and then let ifttt control you toon using HTTP requests
Posted: Mon Mar 11, 2019 4:35 pm
by mbnn
Ok, that however wont make Toon available in Homey to bind Flows to.
For example when temperature is above xx then switch on airco in Homey.
Posted: Mon Mar 11, 2019 5:41 pm
by TheHogNL
You can let your Toon fire an ifttt event when your temperature is at a certain point and then let ifttt start a homey flow.
You need a simple bash script on your Toon checking the temp and then trigger an event on ifttt like this:
curl -X POST
https://maker.ifttt.com/trigger/toon_te ... y/your_key
This works fine. This is what you get if you don't want to pay service money to Eneco
Posted: Tue Mar 12, 2019 9:13 am
by hansgrave
Posted: Tue Mar 12, 2019 9:50 am
by TheHogNL
Nice one. I'm goint to ask if the developer is one of the forum members.
Posted: Tue Mar 12, 2019 10:00 am
by mbnn
That would rock if that works
Maybe the developer can also submit it to the Homey appstore with a different name?
Posted: Thu Mar 14, 2019 6:15 pm
by hansgrave
I installed the app on Homey: now i can see the usage data from Toon and can change temperature or status (sleep, away, comfort etc) with Homey. It have a nice clear design and Toon is easy to connect.
Posted: Sat Mar 16, 2019 12:57 pm
by mbnn
Yes, the only 2 things is that it does not update the current temperature or other things and energy data gives no values. I hope the developer can fix that.
Posted: Mon Mar 18, 2019 2:48 pm
by paul89
mbnn wrote:Yes, the only 2 things is that it does not update the current temperature or other things and energy data gives no values. I hope the developer can fix that.
Are you executing the "Update ..." cards periodically? The app currently does not automatically poll Toon for new data so you have to set up a flow that executes the regarding cards at a desired interval. (I have it setup to run every 5 minutes which is enough for me.)
BTW, I make some contributions to the Homey app (fixes and changes) so if that doesn't work we might be able to further debug it.
Posted: Mon Mar 18, 2019 8:07 pm
by hansgrave
paul89 wrote:mbnn wrote:Are you executing the "Update ..." cards periodically? The app currently does not automatically poll Toon for new data so you have to set up a flow that executes the regarding cards at a desired interval. (I have it setup to run every 5 minutes which is enough for me.
Thanx, the app do update the most important data now! The gas and electra usage doesn't.
Posted: Fri Mar 13, 2020 8:29 pm
by gerbenz
I installed toon app in homey.
Temp works
But electra and gas not.
I have flow to update every 10sec the status
What is wrong?
Posted: Mon Oct 03, 2022 3:14 pm
by hennykarreman
Ik gebruik de Rooted Toon app al een tijdje.
Ik kwam er onlangs achter dat de meterstanden niet meer geupdate worden.
Ik haal de waarden iedere 20 sec op. De Temperatuur en het Vermogen worden wel bijgewerkt.
De laatste waarden zijn van 6 maanden geleden.
Heeft iemand een idee ?
mvg
Henny
Posted: Sat Feb 18, 2023 6:58 pm
by oepi-loepi
De app staat nu in de officiële Homey App Store onder de zoekterm "toonWater" en "toonThermostat". Dus gewoon uit de store te installeren.
Veel aanpassingen gedaan en SDK3 gemaakt.
Posted: Sun Apr 30, 2023 2:42 pm
by Kipsapje
Ik vind alleen toonWater in de store.
Zoek ik verkeerd of is toonThermostat er weer uit gehaald?
Ik heb de Pro 2023
Edit; de toonThermostat app is verwerkt in de toonWater app.
Geroote Toon? --> toonWater app downloaden en gebruiken!
