TOON/OTGW problem
Posted: Wed Mar 13, 2019 10:55 pm
Hello.
I have a Toon thermostat connected to a vaillant vhr 35 c. I was able to connect the Open therm gateway (OTGW) to it. I can read out everything in Domoticz and after a restart and some commands in OTmonitor. Setting things its not possible in Domotiz, sometimes i can set something but then it switchback to the orginal settings. In OTmonitor i can set Central heating temperature and warm water temperature. Is there something more i have to do in Domoticz to make it work. If i understand right i cannot set the room setpoint because its not possible with the vaillant heater i have?
Is there something more to try in Domoticz so the settings work there also?
many thanks.
many thanks.
