Toon for Android
Darkje
Re: Toon for Android
Post by Darkje »
RoadXY wrote: Could you post a screenshot of which field doesn't get filled, please?
It is to big need to edit on the computer.
It says: no chart data available
RoadXY
Post by RoadXY »
Ah the chart yes, I'm working on that
Darkje
Post by Darkje »
@RoadXY i thought you mentioned is was fixxed.
Sorry if i did misunderstood.
RoadXY
Post by RoadXY »
Darkje wrote:@RoadXY i thought you mentioned is was fixxed.
That was another gas issue
Darkje
Post by Darkje »
my bad i guess, just like the way of the chart. Thats some nice eyecandy :-)
RoadXY
Post by RoadXY »
Me to but as stated in another topic on this forum, there seems to be something off with gas and the RRA database:
viewtopic.php?f=104&t=12546
Darkje
Post by Darkje »
@RoadXY, my toon gives the values properly.
So toon knows the proper value's. If that helps you in anyway.
RoadXY
Post by RoadXY »
Darkje wrote:@RoadXY, my toon gives the values properly.
That's facinating.
What firmware version of Toon are you running?
Toon1 or Toon2?
What does HTTP://TOONIP/happ_pwrusage?action=GetCurrentUsage return at your Toon?
{"result":"ok",
"powerUsage": {"value":484, "avgValue":446.53},
"powerProduction": {"value":0, "avgValue":0.00},
"gasUsage": {"value":null,"avgValue":null}
And:
HTTP://TOONIP/hcb_rrd?action=getRrdData ... 1588776543
{ "1588755300": null,"1588755600": null,"1588755900": null,"1588756200": null,"1588756500": null,"1588756800": null,"1588757100": null,"1588757400": null,"1588757700": null,"1588758000": null,"1588758300": null,"1588758600": null,"1588758900": null,"1588759200": null,"1588759500": null,"1588759800": null,"1588760100": null,"1588760400": null,"1588760700": null,"1588761000": null,"1588761300": null,"1588761600": null,"1588761900": null,"1588762200": null,"1588762500": null,"1588762800": null,"1588763100": null,"1588763400": null,"1588763700": null,"1588764000": null,"1588764300": null,"1588764600": null,"1588764900": null,"1588765200": null,"1588765500": null,"1588765800": null,"1588766100": null,"1588766400": null,"1588766700": null,"1588767000": null,"1588767300": null,"1588767600": null,"1588767900": null,"1588768200": null,"1588768500": null,"1588768800": null,"1588769100": null,"1588769400": null,"1588769700": null,"1588770000": null,"1588770300": null,"1588770600": null,"1588770900": null,"1588771200": null,"1588771500": null,"1588771800": null,"1588772100": null,"1588772400": null,"1588772700": null,"1588773000": null,"1588773300": null,"1588773600": null,"1588773900": null,"1588774200": null,"1588774500": null,"1588774800": null,"1588775100": null,"1588775400": null,"1588775700": null,"1588776000": null,"1588776300": null,"1588776600": null}
Darkje
Post by Darkje »
@RoadXY
I get the same value. Gas 0.0 but on my Toon (model 1) the data is there.
I Just got a new firmware. 5.25.8
RoadXY
Post by RoadXY »
Yes, Toon displays them.
That's why I'm searching for the right place for the data
Jasper
Post by Jasper »
As mentioned in the Google play store, I get this error message.
RoadXY
Post by RoadXY »
Jasper wrote:As mentioned in the Google play store, I get this error message.
Which version of the app do you have?
You can check that in the settings of the app or by opening the drawer on the left.
Could you past the outcome of http://[IP-ADDRES-OF-TOON]/hdrv_zwave?action=getDevices.json
Jasper
Post by Jasper »
Version 0.5.10
{"dev_settings_device": {"uuid": "d213df3c-c5dd-4e68-99b7-9128eb1648f8", "name": "settings_device", "internalAddress": "settings_device", "type": "settings_device"}, "dev_14": {"uuid": "e13a535e-ddc7-4739-ac04-f098bad85366", "name": "Lampjes", "internalAddress": "14", "type": "EM6550_v1", "supportsCrc": "0", "ccList": "25 27 72 86 75 73", "supportedCC": "25 27 72 86 75 73", "nodeFlags": [], "TargetStatus": "-1", "CurrentState": "-1", "IsConnected": "0", "HealthValue": "1", "DeviceName": "Lampjes"}, "dev_17": {"uuid": "ccd6f8f3-5770-4b94-804d-ed30b97b1a91", "name": "HAE_METER_v3", "internalAddress": "17", "type": "HAE_METER_v3", "supportsCrc": "1", "ccList": "5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e", "supportedCC": "5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e", "nodeFlags": [], "IsConnected": "1", "DeviceName": "HAE_METER_v3", "HealthValue": "10", "CurrentSensorStatus": "UNKNOWN"}, "dev_17.1": {"uuid": "8ca51e51-4e8b-4fe1-b68b-34767b51c704", "name": "HAE_METER_v3_1", "internalAddress": "17.1", "type": "gas", "supportsCrc": "0", "nodeFlags": [], "CurrentGasFlow": "182.00", "CurrentGasQuantity": "4200174.00", "DeviceName": "HAE_METER_v3_1"}, "dev_17.2": {"uuid": "3c460ec3-833a-4f94-9818-133a05633dbf", "name": "HAE_METER_v3_2", "internalAddress": "17.2", "type": "elec", "supportsCrc": "0", "nodeFlags": [], "CurrentElectricityFlow": "NaN", "CurrentElectricityQuantity": "NaN", "DeviceName": "HAE_METER_v3_2"}, "dev_17.3": {"uuid": "2115f78e-0570-4577-9d37-61568641bf2e", "name": "HAE_METER_v3_3", "internalAddress": "17.3", "type": "elec_solar", "supportsCrc": "0", "nodeFlags": [], "CurrentElectricityFlow": "3797.00", "CurrentElectricityQuantity": "2457127.00", "DeviceName": "HAE_METER_v3_3"}, "dev_17.4": {"uuid": "a16b3a91-63e9-4ec2-929d-4e13a5aecd50", "name": "HAE_METER_v3_4", "internalAddress": "17.4", "type": "elec_delivered_nt", "supportsCrc": "0", "nodeFlags": [], "CurrentElectricityFlow": "0.00", "CurrentElectricityQuantity": "6949199.00", "DeviceName": "HAE_METER_v3_4"}, "dev_17.5": {"uuid": "70be0518-1e82-41a1-9df5-7afc0af4136b", "name": "HAE_METER_v3_5", "internalAddress": "17.5", "type": "elec_received_nt", "supportsCrc": "0", "nodeFlags": [], "CurrentElectricityFlow": "3316.00", "CurrentElectricityQuantity": "4672753.00", "DeviceName": "HAE_METER_v3_5"}, "dev_17.6": {"uuid": "fb56b156-3b42-45f5-a6b8-5fa8598662e0", "name": "HAE_METER_v3_6", "internalAddress": "17.6", "type": "elec_delivered_lt", "supportsCrc": "0", "nodeFlags": [], "CurrentElectricityFlow": "0.00", "CurrentElectricityQuantity": "7782300.00", "DeviceName": "HAE_METER_v3_6"}, "dev_17.7": {"uuid": "4d3da2f1-a06f-4768-9c0b-d52a1d2438e1", "name": "HAE_METER_v3_7", "internalAddress": "17.7", "type": "elec_received_lt", "supportsCrc": "0", "nodeFlags": [], "CurrentElectricityFlow": "0.00", "CurrentElectricityQuantity": "1961202.00", "DeviceName": "HAE_METER_v3_7"}, "dev_17.8": {"uuid": "4a9a478b-bee6-4bd9-b2c9-e8831ff3f78f", "name": "HAE_METER_v3_8", "internalAddress": "17.8", "type": "heat", "supportsCrc": "0", "nodeFlags": [], "CurrentHeatQuantity": "NaN", "DeviceName": "HAE_METER_v3_8"}, "dev_2": {"uuid": "8655ca7c-c82f-4d45-84a9-1e2f8b14c7e3", "name": "Hal", "internalAddress": "2", "type": "EM6550_v1", "supportsCrc": "0", "ccList": "25 27 72 86 75 73", "supportedCC": "25 27 72 86 75 73", "nodeFlags": [], "IsConnected": "1", "HealthValue": "10", "DeviceName": "Hal", "CurrentState": "0", "TargetStatus": "0"}}
RoadXY
Post by RoadXY »
I'll add support for Toon Z-wave devices in 0.5.11
But holy sh*t, that's a lot of previously connected devices in Toon: 17!
Jasper
Post by Jasper »
All I had was two repeaters from Eneco because they couldn't connect the meter adapter to the toon over distance.
Think if you remove one because it lost connection it will add a new instead of overwrite the old one.
