Waterusage
Waterusage
Is there a possibility to monitor the water usage via the optical sensors?
Re: Waterusage
Yes. But unknown how
It is in the Toon sofware but we don't know which hardware to connect to it. We must wait until we see this in production on Toons
- Starting Member
Re: Waterusage
Do you think it can be homebrewed, or would it better to leave the software untouched and wait for the pros to do something about it?
Re: Waterusage
Could it be that this is for detection if water leak?
today i heard an advertising spot from engine Belgium and they were talking about box get an sms when there is an water leak.
Re: Waterusage
Some time ago I bought a pulse generator for my water meter, never used it. Will hook it up to a toon meter adapter in the summer holiday (if I can still find it ), and give it a shot.
- Starting Member
Re: Waterusage
Hi Marcelr, have you had any progress in that project? I had to delay a little bit my home automation project for financial reasons, so I still have time to learn the theory
Re: Waterusage
I just rooted my Toon and was also looking for monitoring water usage.
Found this thread using the search, so is it already possible to get this to work?
Re: Waterusage
While waiting for the post to be approved I found out that that it's not jet possible in the Netherlands. Though I do have a spare port on the meteradapter for gas, the electricity is taken by the solar panels and the S1 is going to the meter port.
Can't the spare gas connector be reprogrammed for water?
Re: Waterusage
No you need the belgian (Boxx) meteradapter for that (also uses the 'gas' connection though). A boxx meteradapter works fine on your dutch toon by the way.Jasper wrote:While waiting for the post to be approved I found out that that it's not jet possible in the Netherlands. Though I do have a spare port on the meteradapter for gas, the electricity is taken by the solar panels and the S1 is going to the meter port.
Re: Waterusage
Thanks, then how do I get one. I checked 2ehands.be and didn't see any.
Re: Waterusage
I got mine from 2dehands.be.
But it's true, they're in short supply.
Re: Waterusage
hi,
last week smart E and Gas meter where installed and those are up and
running via P1
i did also installed 2 2e meetadapter to connect my pulse from the water
meter.
2e meetadapter is added but i cannot choose any item, i do see e/gas/water
but none of them i can select.
how do i add the water sensor?
looking forward of your reply.
best regards peter
running via P1
meter.
best regards peter
Re: Waterusage
Did you ever get this sorted out?Peter06 wrote:hi,
running via P1
meter.
best regards peter
Re: Waterusage
See further above. You need a boxx meteradapter (belgian toon) for thisX1pheR wrote:Did you ever get this sorted out?Peter06 wrote:hi,
running via P1
meter.
best regards peter
Re: Waterusage
Hello, got a boxx meter module and got it connected to my Toon, saw that some off you have it working also, is this with the standard optical sensor?
Or has someone managed to use another sensor?
From sometime ago I had a Sensus HRI-A4 pulse sensor lying around, now I am trying to figure out if I can connect this to the boxx module to read the watermeter.
Someone got an idea if this is possible and how to connect it?
