PW reset RFXCOM LAN
DJF3
PW reset RFXCOM LAN
Post by DJF3 »
Team,
about the password reset of the RFXCOM LAN.
Documentation says:
Make an asynchronous 9600,8,N,1 connection with the embedded controller. The
embedded controller signal level is 3V3 to 5Volt maximum! So don’t connect a standard RS232 connection directly to this interface!
A valid connection can be done using one of the following methods:
a. Insert the RFXCOM RS232 serial module in JP5.
b. Use an RFXCOM USB interface. Remove receivers or transmitter from the USB
interface, connect the following pins between the USB interface and the Ethernet
interface. JP1-14 to JP5-14, JP1-8 to JP5-9, JP1-9 to JP5-8.
as I don't have an RFXCOM RS232 or RFXCOM USB I was wondering: is there a different way to do the password reset, possibly using an FTDI Adapter FT232RL USB naar TTL Serial voor 3,3V en 5V
