Toonstore installeert niet
PetervdK
Re: Toonstore installeert niet
Post by PetervdK »
TheHogNL wrote: Doe maar even met optie -v 5.25. 8 (dan negeert hij je oude versie)
Stom zeg, ik had inderdaad van de week ergens gelezen dat er een -v optie is... :oops:
Upgrade naar 5.25.8 loopt :D
En inmiddels afgerond, store werkt als een trein.
Thanks!
PeJeWe
Post by PeJeWe »
toon 1 with version 5.49.19
toonstore wont let me install apps.
I have removed the toonstore app from the /qmf/qml/apps
and then run sh /root/update-rooted.sh -f
Version: 4.80  - TheHogNL - 03-01-2023
Only fixing files.
creating backup of inittab...
creating backup of hosts...
FIXING: Downloading resources.rcc TSC mod for this version 5.49.19.
-- Updating custom app toonstore to release 5.1.3 ... DONE
EDITING: disabling Eneco subscription feature apps to free up memory on this toon 1
EDITING: disabling samba nmbd on toon 1 as probably it is not necessary
Finished fixing files!
after that i did a soft reboot and checked the toonstore the apps, they are beeing loaded, only when i select a app and try to install it it don't get installed
PeJeWe
Post by PeJeWe »
has no one a solution?
oepi-loepi
Post by oepi-loepi »
Think you have damaged the scripts on your toon. Maybe you can do a full update to the same version (using -v 5.49.19). Otherwise restore to original firmware and do the rooting again.
Can you check the tsc log file for error messages (/var/log/tsc)?
If an install from the ToonStore failes, I expect you will see an error message in this logfile.
If you don't see anything in the logfile or the logfile doesn't exist then probably the tsc script is not running at all (/usr/bin/tsc)
PeJeWe
Post by PeJeWe »
I will check it this evening
PeJeWe
Post by PeJeWe »
Toonz wrote: Wed Mar 08, 2023 10:35 am Can you check the tsc log file for error messages (/var/log/tsc)?
there is no tsc log in the /var/log/tsc directory.
however there is a message file witch contains errors:
Mar  8 12:18:27 eneco-001-289*** daemon.info init: Id "tscs" respawning too fast: disabled for 5 minutes
Mar  8 12:23:28 eneco-001-289*** daemon.info init: Id "tscs" respawning too fast: disabled for 5 minutes
Mar  8 12:28:29 eneco-001-289*** daemon.info init: Id "tscs" respawning too fast: disabled for 5 minutes
Mar  8 12:33:30 eneco-001-289*** daemon.info init: Id "tscs" respawning too fast: disabled for 5 minutes
Mar  8 12:36:05 eneco-001-289*** user.warn kernel: Rcv Wcid(1) AddBAReq
Mar  8 12:36:05 eneco-001-289*** user.warn kernel: Start Seq = 000003a5
Mar  8 12:38:25 eneco-001-289*** user.warn kernel: Rcv Wcid(1) AddBAReq
Mar  8 12:38:25 eneco-001-289*** user.warn kernel: Start Seq = 000003cd
Mar  8 12:38:31 eneco-001-289*** daemon.info init: Id "tscs" respawning too fast: disabled for 5 minutes
Mar  8 12:40:42 eneco-001-289*** user.warn kernel: Rcv Wcid(1) AddBAReq
Mar  8 12:40:42 eneco-001-289*** user.warn kernel: Start Seq = 000003fd
Mar  8 12:42:58 eneco-001-289*** user.warn kernel: Rcv Wcid(1) AddBAReq
Mar  8 12:42:58 eneco-001-289*** user.warn kernel: Start Seq = 00000422
Mar  8 12:43:32 eneco-001-289*** daemon.info init: Id "tscs" respawning too fast: disabled for 5 minutes
Mar  8 12:45:13 eneco-001-289*** user.warn kernel: Rcv Wcid(1) AddBAReq
Mar  8 12:45:13 eneco-001-289*** user.warn kernel: Start Seq = 0000044c
Mar  8 12:46:22 eneco-001-289*** user.warn kernel: Rcv Wcid(1) AddBAReq
Mar  8 12:46:22 eneco-001-289*** user.warn kernel: Start Seq = 00000478
Mar  8 12:48:33 eneco-001-289*** daemon.info init: Id "tscs" respawning too fast: disabled for 5 minutes
Mar  8 12:50:47 eneco-001-289*** user.warn kernel: Rcv Wcid(1) AddBAReq
Mar  8 12:50:47 eneco-001-289*** user.warn kernel: Start Seq = 000004cb
Mar  8 12:53:01 eneco-001-289*** user.warn kernel: Rcv Wcid(1) AddBAReq
Mar  8 12:53:01 eneco-001-289*** user.warn kernel: Start Seq = 000004f3
Mar  8 12:53:34 eneco-001-289*** daemon.info init: Id "tscs" respawning too fast: disabled for 5 minutes
Mar  8 12:56:26 eneco-001-289*** user.warn kernel: Rcv Wcid(1) AddBAReq
Mar  8 12:56:26 eneco-001-289*** user.warn kernel: Start Seq = 00000543
Mar  8 12:58:35 eneco-001-289*** daemon.info init: Id "tscs" respawning too fast: disabled for 5 minutes
Mar  8 13:01:00 eneco-001-289*** user.warn kernel: Rcv Wcid(1) AddBAReq
Mar  8 13:01:00 eneco-001-289*** user.warn kernel: Start Seq = 0000059b
Mar  8 13:03:07 eneco-001-289*** user.warn kernel: Rcv Wcid(1) AddBAReq
Mar  8 13:03:07 eneco-001-289*** user.warn kernel: Start Seq = 000005c7
Mar  8 13:03:36 eneco-001-289*** daemon.info init: Id "tscs" respawning too fast: disabled for 5 minutes
Mar  8 13:08:38 eneco-001-289*** daemon.info init: Id "tscs" respawning too fast: disabled for 5 minutes
Mar  8 13:13:40 eneco-001-289*** daemon.info init: Id "tscs" respawning too fast: disabled for 5 minutes
how can i run the script at startup, with cron?
the tsc script is started automatically after a full reboot (not after a qui restart) via this line in /etc/inittab:
tscs:245:respawn:/usr/bin/tsc >/var/log/tsc 2>&1
Seems like something is wrong with your firmware, a recovery procedure is an option to fix that
PeJeWe
Post by PeJeWe »
Ok, i will do a recovery.
Is the toon fully reset then, and all the data lost?
I want to reset the toon fully to its clean state.
oepi-loepi
Yes, that is a recovery.. full restore.
PeJeWe
Post by PeJeWe »
I have successfully did a recovery by formatting the toon
And installed firmware 5.0.x
And restored the VPN settings.
The tsc is working again.
PeJeWe
Post by PeJeWe »
install package openssh-sftp-server
i get an error installing:
Unknown package 'openssh-sftp-server'.
Collected errors:
 * pkg_hash_fetch_best_installation_candidate: Packages for openssh-sftp-server found, but incompatible with the architectures configured
 * opkg_install_cmd: Cannot install package openssh-sftp-server.
