Toon firmware 5.25.8 released??
Havym
Post by Havym »
Is there a new release for the rooted community and is it safe to install on my rooted tone?
Just asking just to be sure i dont mess up my toon.
Re: Toon firmware 5.28.8 released??
Post by TheHogNL »
I don't know anythign about 5.28.8. Where did you see that?
TerrorSource
Post by TerrorSource »
You can see all checked versions here: https://github.com/ToonSoftwareCollecti ... onversions
Havym
Post by Havym »
I'm sorry.... to much number 8 :shock:
I saw 5.25.8 on my Toon appear today... i checked the list so i can update safely :D
Re: Toon firmware 5.25.8 released??
Post by TheHogNL »
Yes you can update to 5.25.8, no problem. However there is always a slight possibility that something goes wrong.
Joskep
Post by Joskep »
Since the last update today the Toon responses allmost directly after touching while in dimmode. I don.t know if that was the meaning, but thanks :-) :D
TerrorSource
We have pulled 5.28.6 for rooted Toon's a few minutes ago. There's a substantial possibility that the Toon loses his root.
If this happens with your rooted Toon, we are working on a solution but the Toon must be re-rooted for now.
Joskep
Post by Joskep »
Mmm hopefully it stil works ;-( I just updated to this firmware.
If everything works the same, the Toonstore is present, then i don.t have to worry?
Hopefully you can explain how i can see its still rooted., SSH acces as ROOT stil works.
TerrorSource
Joskep wrote:Mmm hopefully it stil works ;-( I just updated to this firmware.
if you update from 5.22.14 or 5.25.8 you shouldn't have any issues.
If you update from versions before 5.22.14 you *might* have issues
Joskep
Post by Joskep »
Thanks!! I updated from 5.28.8
Post by TheHogNL »
If toonstore is present you don't need to worry.
michel30
Post by michel30 »
Is it okay for the Toon 1 to update to the latest firmware? or could I better wait that the new script is released to do the upgrade?
Thanks,
TerrorSource
michel30 wrote:Hello,
Thanks,
script is already updated.
You can update to 5.28.6 from 5.22.14 or 5.25.8
If you are on a version lower then 5.22.14 you need to go to 5.25.8 first, then update to a newer version.
Post by TheHogNL »
And for a Toon1 there was no issue and no need to update to 5.26.8 first.
NLKris
Post by NLKris »
Found out that Philips hue not always worked on firmware 5.25.8. 'New' Toons didn't ask me to connect my Hue bridge. Also a search in the menu didn't work out.
So I updated to 5.28.6 and since then it working fine again. If you might have trouble using hue on 5.25.8, maybe 5.28.6 is also the solution for you!
Greetz.
Return to “Toon Firmware”
