Firmware 5.28.9
Firmware 5.28.9
Somebody tested this newest version?
Re: Firmware 5.28.9
Yes safe to install. Just same functions as 5.28.6 but then with the toon2 update issue fixed.Joskep wrote:Somebody tested this newest version?
Re: Firmware 5.28.9
Updated to 5.28.9 on my Toon 1 it seems like it reacts much faster now!
Homey, rooted Toon 1 and HomeAssistent.
Re: Firmware 5.28.9
Same here, pretty fast.
And there seem to be a symbol in de left power corner.
Dont know what is does.
Re: Firmware 5.28.9
by pressing that button you can start rotating homescreenpages when in dim modeDarkje wrote:Same here, pretty fast.
Re: Firmware 5.28.9
@toonz thnx.
This firmware jeeps awesome. It is still fast and really responsive. I wonder what they changed.
Re: Firmware 5.28.9
There is also a green leafe if your temp setpoint is below 19,5
Re: Firmware 5.28.9
hmmm, most of the recent versions did not add any new relevant functionality, mainly fixing their own bugs they created themselves in earlier releases.Darkje wrote:@toonz thnx.
But that approach is working, everyone is happy now with the fast responding screen after they screwed up. It is a way to get happy customers indeed
Re: Firmware 5.28.9
@Toonz, It is actually a difference of day and night.
Its not 3%faster. I think it is like 300% faster.
Re: Firmware 5.28.9
I updated from 5.22.14 -> 5.28.9 and also noticed better responsiveness overall.
But unfortunately the z-wave connection became very unstable since the update resulting in zeroed out readings and gray segments in the metering details.
I unpaired->paired the meter-adapter which did not help, and the distance between Toon and the meter-adapter is +/-6m.
It worked flawlessly for the past year, and the times I checked it always showed 5 stars for the connection status, but now it sometimes show 5, other times 1, and most times none at all .
Anyone else noticed z-wave problems with the meter-adapter since the update?
- Benjamin Disraeli -
Re: Firmware 5.28.9
First time I hear this. There wasn't a z-wave part update also from your firmware to 5.28.9 so i'm guessing it is something else. Don't know whatTimeless wrote: Anyone else noticed z-wave problems with the meter-adapter since the update?
Re: Firmware 5.28.9
Yeah I have no idea what it could be.
I've power cycled Toon and this seem to have improved it a bit.
But I do still see these messages in the logfiles:
Very strange why it's showing "invalidDevice" since I only have one meteradapter bound to Toon.
["2020-05-31 14:14:21 +0200",10,2,0,"Connection of module intAddr:%s devType:%s changed to %s",["HIDDEN","ZWAVE_HAE_METER_v2","NCONN"]],
["2020-05-31 14:14:33 +0200",10,2,0,"Connection of module intAddr:%s devType:%s changed to %s",["HIDDEN","ZWAVE_HAE_METER_v2","OK"]],
["2020-05-31 14:37:17 +0200",10,2,0,"Connection of module intAddr:%s devType:%s changed to %s",["HIDDEN","ZWAVE_HAE_METER_v2","NCONN"]],
["2020-05-31 14:37:24 +0200",10,2,0,"Connection of module intAddr:%s devType:%s changed to %s",["HIDDEN","ZWAVE_HAE_METER_v2","OK"]],
["2020-05-31 14:44:17 +0200",10,2,0,"Connection of module intAddr:%s devType:%s changed to %s",["HIDDEN","ZWAVE_HAE_METER_v2","NCONN"]]
["2020-05-31 20:00:07 +0200",99,4,0,"%s",["HAE_METER_v2 CRC ERROR data:
["2020-05-31 10:19:51 +0200",93,1,0,"%s",["First test gave error rate of 0, stop the rest and give full marks"]],
["2020-05-31 10:19:51 +0200",93,1,0,"%s",["RESULT: plv:9rnd:[1/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=53533 nhv=10"]],
["2020-05-31 10:19:51 +0200",93,1,0,"%s",["HealthValue Device HAE_METER_v2 intAddr 9 value 10"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:0rnd:[1/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=266478 nhv=1"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:1rnd:[2/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=67986 nhv=1"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:2rnd:[3/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=68794 nhv=2"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:3rnd:[4/10] SENT=50 ACK=49 NO_ACK=1 ERROR=0 AVGTIME=83144 nhv=2"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:4rnd:[5/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=31974 nhv=3"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:5rnd:[6/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=75170 nhv=3"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:6rnd:[7/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=77521 nhv=4"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:7rnd:[8/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=100758 nhv=6"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:8rnd:[9/10] SENT=50 ACK=48 NO_ACK=2 ERROR=0 AVGTIME=92985 nhv=8"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:9rnd:[10/10] SENT=50 ACK=42 NO_ACK=8 ERROR=0 AVGTIME=100949 nhv=8"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["HealthValue Device HAE_METER_v2 intAddr 9 value 8"]],
["2020-05-31 14:20:13 +0200",93,1,0,"%s",["RESULT: plv:0rnd:[1/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=287785 nhv=1"]],
["2020-05-31 14:20:13 +0200",93,1,0,"%s",["RESULT: plv:1rnd:[2/10] SENT=50 ACK=39 NO_ACK=11 ERROR=0 AVGTIME=184448 nhv=1"]],
["2020-05-31 14:20:13 +0200",93,1,0,"%s",["HealthValue Device HAE_METER_v2 intAddr 9 value 1"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:0rnd:[1/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=118737 nhv=1"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:1rnd:[2/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=25159 nhv=1"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:2rnd:[3/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=37335 nhv=2"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:3rnd:[4/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=53176 nhv=2"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:4rnd:[5/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=58335 nhv=3"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:5rnd:[6/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=37356 nhv=3"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:6rnd:[7/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=37141 nhv=4"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:7rnd:[8/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=61345 nhv=6"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:8rnd:[9/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=59168 nhv=8"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:9rnd:[10/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=77384 nhv=10"]],
["2020-05-31 13:09:42 +0200",98,1,0,"%s",["MeterAdapter restarted uuid=NUMBER1 nodeID=9"]],
["2020-05-31 13:09:52 +0200",98,2,0,"invalidDevice c:device i:NUMBER2"],
["2020-05-31 13:11:27 +0200",98,2,0,"invalidDevice c:device i:NUMBER2"],
["2020-05-31 13:17:15 +0200",98,2,0,"invalidDevice c:device i:NUMBER2"],
["2020-05-31 13:24:36 +0200",98,2,0,"invalidDevice c:device i:NUMBER2"],
["2020-05-31 13:25:10 +0200",98,2,0,"invalidDevice c:device i:NUMBER2"],
Re: Firmware 5.28.9
Try to 'remove all meteradapters'' in the advanced meter adapter configuration screen and then re-add it.
Re: Firmware 5.28.9
Ok, going to give that a try.
Does that reset the homeID of Open-Zwave so instead of nodeID=9 it will become nodeID=1 again?
It's still strange that it mentions a invalidDevice while there is only one meter-adapter plugged in.
And, does Toon trigger this restart or did the meter-adapter somehow crash?
