Page 2 of 2
Re: Firmware 5.28.9
Posted: Sun May 31, 2020 10:13 pm
by PeJeWe
TheHogNL wrote:
Timeless wrote: Anyone else noticed z-wave problems with the meter-adapter since the update?
First time I hear this. There wasn't a z-wave part update also from your firmware to 5.28.9 so i'm guessing it is something else. Don't know what
After the update I do have P1 port electric, but no gas count for the day.
When I press the button then is see it register gas, but I don't see it on the tile.
Re: Firmware 5.28.9
Posted: Mon Jun 01, 2020 12:14 am
by Timeless
Ok I've pressed "remove all meteradapters & repeaters" and this is the result:
["2020-05-31 23:21:44 +0200",93,1,0,"%s",["Controller HomeID HIDDEN, NodeID 001, SerialAPIVer 5, chip_type 03 chip_version 01"]],
["2020-05-31 23:21:44 +0200",93,1,0,"%s",["Listening nodes registered 0 (total: 0)"]],
["2020-05-31 23:23:48 +0200",93,1,0,"%s",["Node 9 sends nodeinformation"]],
["2020-05-31 23:24:24 +0200",93,1,0,"%s",["Controller HomeID HIDDEN, NodeID 001, SerialAPIVer 5, chip_type 03 chip_version 01"]],
["2020-05-31 23:24:24 +0200",93,1,0,"%s",["Node:009 Listening:TRUE  FLiRS:FALSE"]],
["2020-05-31 23:24:24 +0200",93,1,0,"%s",["Listening nodes registered 1 (total: 1)"]],
["2020-05-31 23:24:45 +0200",93,1,0,"%s",["First test gave error rate of 0, stop the rest and give full marks"]],
["2020-05-31 23:40:09 +0200",93,1,0,"%s",["RESULT: plv:0rnd:[1/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=95450 nhv=1"]],
["2020-05-31 23:40:09 +0200",93,1,0,"%s",["RESULT: plv:1rnd:[2/10] SENT=50 ACK=47 NO_ACK=3 ERROR=0 AVGTIME=67954 nhv=1"]],
["2020-05-31 23:40:09 +0200",93,1,0,"%s",["RESULT: plv:2rnd:[3/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=38350 nhv=2"]],
["2020-05-31 23:40:09 +0200",93,1,0,"%s",["RESULT: plv:3rnd:[4/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=68150 nhv=2"]],
["2020-05-31 23:40:09 +0200",93,1,0,"%s",["RESULT: plv:4rnd:[5/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=66593 nhv=3"]],
["2020-05-31 23:40:09 +0200",93,1,0,"%s",["RESULT: plv:5rnd:[6/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=67146 nhv=3"]],
["2020-05-31 23:40:09 +0200",93,1,0,"%s",["RESULT: plv:6rnd:[7/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=57763 nhv=4"]],
["2020-05-31 23:40:09 +0200",93,1,0,"%s",["RESULT: plv:7rnd:[8/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=71983 nhv=6"]],
["2020-05-31 23:40:09 +0200",93,1,0,"%s",["RESULT: plv:8rnd:[9/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=70578 nhv=8"]],
["2020-05-31 23:40:09 +0200",93,1,0,"%s",["RESULT: plv:9rnd:[10/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=76566 nhv=10"]],
["2020-05-31 23:40:09 +0200",93,1,0,"%s",["HealthValue Device HAE_METER_v2 intAddr 9 value 10"]],
["2020-05-31 23:40:49 +0200",93,1,0,"%s",["RESULT: plv:0rnd:[1/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=79723 nhv=1"]],
["2020-05-31 23:40:49 +0200",93,1,0,"%s",["RESULT: plv:1rnd:[2/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=40574 nhv=1"]],
["2020-05-31 23:40:49 +0200",93,1,0,"%s",["RESULT: plv:2rnd:[3/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=37336 nhv=2"]],
["2020-05-31 23:40:49 +0200",93,1,0,"%s",["RESULT: plv:3rnd:[4/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=51175 nhv=2"]],
["2020-05-31 23:40:49 +0200",93,1,0,"%s",["RESULT: plv:4rnd:[5/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=76795 nhv=3"]],
["2020-05-31 23:40:49 +0200",93,1,0,"%s",["RESULT: plv:5rnd:[6/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=69985 nhv=3"]],
["2020-05-31 23:40:49 +0200",93,1,0,"%s",["RESULT: plv:6rnd:[7/10] SENT=50 ACK=49 NO_ACK=1 ERROR=0 AVGTIME=87767 nhv=4"]],
["2020-05-31 23:40:49 +0200",93,1,0,"%s",["RESULT: plv:7rnd:[8/10] SENT=50 ACK=47 NO_ACK=3 ERROR=0 AVGTIME=120946 nhv=6"]],
["2020-05-31 23:40:49 +0200",93,1,0,"%s",["RESULT: plv:8rnd:[9/10] SENT=50 ACK=46 NO_ACK=4 ERROR=0 AVGTIME=88975 nhv=6"]],
["2020-05-31 23:40:49 +0200",93,1,0,"%s",["RESULT: plv:9rnd:[10/10] SENT=50 ACK=0 NO_ACK=50 ERROR=0 AVGTIME=0 nhv=6"]],
["2020-05-31 23:40:49 +0200",93,1,0,"%s",["HealthValue Device HAE_METER_v2 intAddr 9 value 6"]],
["2020-05-31 23:41:37 +0200",93,1,0,"%s",["RESULT: plv:0rnd:[1/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=0 nhv=1"]],
["2020-05-31 23:41:37 +0200",93,1,0,"%s",["RESULT: plv:1rnd:[2/10] SENT=50 ACK=48 NO_ACK=2 ERROR=0 AVGTIME=99636 nhv=1"]],
["2020-05-31 23:41:37 +0200",93,1,0,"%s",["RESULT: plv:2rnd:[3/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=100538 nhv=2"]],
["2020-05-31 23:41:37 +0200",93,1,0,"%s",["RESULT: plv:3rnd:[4/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=112774 nhv=2"]],
["2020-05-31 23:41:37 +0200",93,1,0,"%s",["RESULT: plv:4rnd:[5/10] SENT=50 ACK=49 NO_ACK=1 ERROR=0 AVGTIME=98553 nhv=3"]],
["2020-05-31 23:41:37 +0200",93,1,0,"%s",["RESULT: plv:5rnd:[6/10] SENT=50 ACK=45 NO_ACK=5 ERROR=0 AVGTIME=106151 nhv=3"]],
["2020-05-31 23:41:37 +0200",93,1,0,"%s",["RESULT: plv:6rnd:[7/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=78939 nhv=3"]],
["2020-05-31 23:41:37 +0200",93,1,0,"%s",["RESULT: plv:7rnd:[8/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=79772 nhv=3"]],
["2020-05-31 23:41:37 +0200",93,1,0,"%s",["RESULT: plv:8rnd:[9/10] SENT=50 ACK=48 NO_ACK=2 ERROR=0 AVGTIME=91747 nhv=3"]],
["2020-05-31 23:41:37 +0200",93,1,0,"%s",["RESULT: plv:9rnd:[10/10] SENT=50 ACK=48 NO_ACK=2 ERROR=0 AVGTIME=95599 nhv=3"]],
["2020-05-31 23:41:37 +0200",93,1,0,"%s",["HealthValue Device HAE_METER_v2 intAddr 9 value 3"]]
So it's still NodeID9 yet the only one listening, is there any way to reach the ozwcp on Toon?
Re: Firmware 5.28.9
Posted: Mon Jun 01, 2020 12:36 am
by marcelr
ozwcp is not part of the standard software on toon. You can install it though, and then access is through a standard http browser.
Re: Firmware 5.28.9
Posted: Mon Jun 01, 2020 12:56 am
by Timeless
Ah ok, but then it probably means that ozwcp and HCBv2 cannot access the zwave controller simultaneously right?
Is it normal for the meteradapter to become NodeID9? Because I've cleared all meter adapters several times and it still keeps NodeID9. I even tried holding the button on the adapter itself for more than 10sec but this does nothing.
Re: Firmware 5.28.9
Posted: Mon Jun 01, 2020 9:35 am
by TheHogNL
Please try this:
 sed -i "s/configStatus\.supportControl == '0'/configStatus.supportControl == '-1'/" /qmf/www/hdrv_zwave/js/zwave.js
And then go to http://toon-ip/hdrv_zwave/ (the trailing / must be there). Maybe you can fix your problem using that zwave control page.
Re: Firmware 5.28.9
Posted: Mon Jun 01, 2020 3:07 pm
by Timeless
Ah that interface does give me some options.
I do see one node NodeID9 with 6 Subdevice endPoint: X name: HAE_METER_v2_X devices, some have CurrentSensorStatus UNKNOWN others are OPERATIONAL, these are probably the individual analog and P1 gas/electric measurements?
There is a factory reset option, maybe this clears everything up, does it have any negative impact if I press that button?
Re: Firmware 5.28.9
Posted: Mon Jun 01, 2020 4:10 pm
by TheHogNL
Timeless wrote:Ah that interface does give me some options.
Haven't used it before but I am pretty sure you can always recover from a potential failure. I think it just resets the configuration completly.
Re: Firmware 5.28.9
Posted: Mon Jun 01, 2020 6:21 pm
by Timeless
Ok, I've used the factory reset option and this did indeed change the HomeID and my single meteradapter now got NodeID2 just like it should. So time will tell if this helped somehow.
Re: Firmware 5.28.9
Posted: Tue Jun 23, 2020 10:57 pm
by michel30
I see on my Toon 1 that there is a new firmware released Firmware 5.30.1 ... is that one safe?
And what is new in this firmware?
Re: Firmware 5.28.9
Posted: Tue Jun 23, 2020 11:17 pm
by marcelr
Probably 5.30.4, it's been released today. If it's being offered to you via TSC it should be OK to install.
Not sure about novelties, probably not an awful lot, it's hardly ever worth mentioning these days.
Re: Firmware 5.28.9
Posted: Tue Jun 23, 2020 11:29 pm
by TerrorSource
There's no official changelog but a user on ToonForum posted it.
https://toonforum.nl/d/4-softwareversie-overzicht/59
It's 5.30.4.
Its checked by us and works fine thats why you see the update :)
Re: Firmware 5.28.9
Posted: Wed Jun 24, 2020 11:48 am
by michel30
Thanks for the information.
