Plugwise Pro update --> 4.0.0.9
Wima
Post by Wima »
I was updating my HS3 plugins but did get an error installing Plugwise Pro. At this moment 3.0.3.2 installed.
In the upgrade manual on HS forum you mentioned prior to the 4.0.0.X version first install the lagecy version.
The lagacy version is the same as my installed version, so, already running. Any clues how to get to 4.0.0.9 ?
The error: Install/Update of package Plugwise Pro failed.
Thanks
even the genious ask questions
Akatar
Re: Plugwise Pro update --> 4.0.0.9
Post by Akatar »
you have to disable the plugin first,
then update --> enable plugin
Wima
Post by Wima »
Of course, that is what I did but it doesn't work
Akatar
Post by Akatar »
Then it's time to send a message to stef
viewtopic.php?f=39&t=12456
Wima
Post by Wima »
stefxx
Post by stefxx »
If the update keeps failing, stop the plugin, and restart homeseer. Or just restart Windows if needed. It usually means something is stuck.
Return to “Plugwise Forum”
