Rooted Toon and Google home mini
Bruce the boss
Post by Bruce the boss »
I do have a Google home mini and a rooted Toon and before the Toon was rooted I was able to change the temp. form Toon with the Google home mini.
Because of the rooted Toon I don't have a Eneco account anymore and "because of that" the connection between Toon and the Google home mini is lost.
Is there a way to solve this so I can connect Toon to Google?
Thanks a lot for your help in advance.
mAiden
Re: Rooted Toon and Google home mini
Post by mAiden »
It can.
You need to use Home Assistant to connect Rooted Toon to Google Home
Bruce the boss
Do you mean with Olisto?
I was able add Toon but when I give a command it doesn't work.
mAiden
Post by mAiden »
No. Olisto needs a Toon subscription to connect it to Google home..
You are Home Assistant needed (word is clickable for more information about Home Assistant.)..
When you get that, then you ready for the next stap..
Connect Home Assistant to Google Home. You don't need a cloud connection from Home Assistant to get that done (Cloud also costs money.)
It will not be easy, but it is certainly possible .. I also managed to do it.
Bruce the boss
Okay from the end of this week on I will have a Raspberry Pi 3 Model B and B+ 32bit so I will give it a try in the next days.
I think I will need your help :)
mAiden
Post by mAiden »
Bruce the boss wrote:Okay from the end of this week on I will have a Raspberry Pi 3 Model B and B+ 32bit so I will give it a try in the next days.
It's ok. Let me know when you need my help. :)
Return to “Toon Rooting”
