Lose connection between TOON and meetmodule
Posted: Thu Jul 16, 2020 2:15 pm
by Bruce the boss
Sinds the last days I have the problem that I lose connection between the Toon and the "meetmodule".
I have been in contact with Eneco and I understood from them that this is a software issue from the Toon.
According them this will be solved in the next software update.
Is this a known issue for you and will this be solved indeed in the next update from this board?
Thanks for your reply.
Re: Lose connection between TOON and meetmodule
Posted: Thu Jul 16, 2020 2:50 pm
by TerrorSource
We briefly check each official update, if found OK we "release" it to rooted Toon's by adding the version to a GitHub file.
Rooted Toon's check that GitHub file once a day. If a newer version is found, the Toon opens the connection to the update-server to download the update.
Then the update is installed and the Toon keeps it root automagically
Posted: Thu Jul 16, 2020 2:59 pm
by Bruce the boss
Thanks for your reply and do you recognize this "problem" between TOON and the "meetmodule"?
Posted: Thu Jul 16, 2020 3:05 pm
by TerrorSource
Bruce the boss wrote:Thanks for your reply and do you recognize this "problem" between TOON and the "meetmodule"?
to be honest, i don't.
Did you already "forget-and-reconnect" the meteradapter?
meteradapter connects to the Toon via Z-wave. Z-wave should not have interferance from Wifi or other Z-wave networks on the 868.42 MHz band.
Only DECT-phones can cause interferance.
Posted: Thu Jul 16, 2020 3:09 pm
by Bruce the boss
I don't overdramatic when I say I have done this more then 10 times.
It worked well for months and sinds the last two weeks I have problems with this.
Could there be another solution for this?
Posted: Thu Jul 16, 2020 3:19 pm
by TerrorSource
Bruce the boss wrote:I don't overdramatic when I say I have done this more then 10 times.
Did you do the "Verwijderen" and "Herstellen" options under Advanced? other solution is to replace the meteradapter and give that a try.
Posted: Thu Jul 16, 2020 4:32 pm
by Bruce the boss
TerrorSource wrote:Bruce the boss wrote:I don't overdramatic when I say I have done this more then 10 times.
Yes I did both bud without any success.
I will disconnect the module as I follow my energy consumption via a external website.
Thanks for your help anyway.
Posted: Tue Jan 26, 2021 2:29 pm
by Tebogo
Did you eventually solve the problem. I still have issues with de Metermodule. After I get a confirmed connection on the Toon it loses the connection, distance only 50 cm.
What can cause this, and how to solve....
Thank you!
