Firmware 5.33.9
whizzz63
Firmware 5.33.9
Post by whizzz63 »
Is it safe to install?
5.33.9
Re: Firmware 5.33.9
yes
whizzz63
Re: Firmware 5.33.9
Post by whizzz63 »
Thanks! You know what's been changed?
timkoers
Re: Firmware 5.33.9
Post by timkoers »
Did anyone notice the new 'Slim verwarmen' menu option? What does it do? On my Toon is just fails.
Re: Firmware 5.33.9
Post by TheHogNL »
timkoers wrote:Did anyone notice the new 'Slim verwarmen' menu option? What does it do? On my Toon is just fails.
It is for toon subscriptions only. It asks the servicecenter to calculate if lowering your thermostat setpoint from for example 21 to 19 degrees would spare you money.
As it is not working for rooted toons I am thinking of removing the app from the resource files for rooted toons. It will safe some memory for the toon1
Re: Firmware 5.33.9
Post by TheHogNL »
It was easier to remove that I anticipated :-)
Change in /qmf/qml/config/TenantSettings.json "appHeatingOverviewEnabled" to 'false'.
New update-rooted scripts fixes this already for you.
Nabson
Re: Firmware 5.33.9
Post by Nabson »
I've updated my toon today to 5.33.9 but Toonstore remains empty now (it shows 0 apps in the Toonstore).
Did the update with the update script. Are you expecting the same? How should I solve this?
Re: Firmware 5.33.9
Post by TheHogNL »
Nabson wrote:I've updated my toon today to 5.33.9 but Toonstore remains empty now (it shows 0 apps in the Toonstore).
Can be temporarly internet issue on your side or the server. Does it work a hours later?
Nabson
Re: Firmware 5.33.9
Post by Nabson »
I did a check this morning, but still 0 apps in Toonstore.
Re: Firmware 5.33.9
Nabson wrote:I did a check this morning, but still 0 apps in Toonstore.
Can happen when the catalog file cannot be retrieved from github (either because of internet issues at your end or a service interruption at github).
Have you tried to manually refresh the ToonStore catalog (refresh button next to the Instellingen button)?
Should be working fine now.
Re: Firmware 5.33.9
Post by TheHogNL »
Did you try a reboot?
Re: Firmware 5.33.9
Post by TheHogNL »
Should work now. The xml list file for toonstore had an error after a new version for the PostNL app was added yesterday.
Nabson
Re: Firmware 5.33.9
Post by Nabson »
It’s working again (without reboot). Thanks all!
Return to “Toon Firmware”
