Failed to update from version 4.32
Re: Failed to update from version 4.32
Post by TheHogNL »
Erwin033 wrote:That would be very hard. I didnt root my toon by myself..
it isn’t possible to fix the problem with the command line? That would be easier for me.
Would require knowledge what is going on. Can you send me a PM with your mobile number? I will whatsapp you then so I can help you over teamviewer.
dote81
Post by dote81 »
Erwin033 wrote:Hello,
Would anyone help me to understand why the update script wouldn't work.
I never updated the toon before.
This is the output I recieved:
sh /root/update-rooted.sh
Welcome to the rooted Toon upgrade script. This script [url=https://bestdoorbellcamera2021.com/do-doorbell-cameras-record-all-the-time/]will try[/url] to upgrade your Toon using your original connection with Eneco. It will start the VPN if necessary.
Version: 4.32  - TheHogNL & TerrorSource & yjb - 16-11-2020
If you like the update script for rooted toons you can support me. Any donation is welcome and helps me developing the script even more.
https://paypal.me/pools/c/8bU3eQp1Jt
Warning: there is a new version of update-rooted.sh available! Do you want me to download it for you (yes/no)?
yes
Ok I downloaded the update. Restarting...
Version: 4.33  - TheHogNL & TerrorSource & yjb - 26-11-2020
Your Toon already tried downloading version 4.19.10 before. Need to force this version!
Upgrade script downloaded. We need to download the upgrade files first. No upgrade is done yet. Do you want me to download the files (yes) or quit (anything else)?
yes
First removing some files to free some disk space. Removed 'ebl' resource files because this toon is using 'base' resource files.
Waiting to finish. Sometimes this takes a minute or two    .
Prepare failed. Please check the logs at /mnt/data/update/upgrade-qb2.sh.log
Thank you
Return to “Toon Firmware”
